Rear end out of a dune buggy I disassembled a very old dune buggy about 35 years ago. Did not want my son and his buddies to kill themselves. It was a shortened flathead chassis of an unknown year. Here is the rear end. What year might it be.
https://i.imgur.com/yQRVIK9l.jpg https://i.imgur.com/UgcLSYrl.jpg I also have the front axle, wishbone and spring. We will be moving and I do not want to take it with me. |
Re: Rear end out of a dune buggy measure across where the brake backing plates mount, thats the normal method to id it
Re: Rear end out of a dune buggy Looks like 37-40 at first glance.
Is there just a single eye on the spring perches? |
Re: Rear end out of a dune buggy Quote:
Re: Rear end out of a dune buggy Top of front axle
https://i.imgur.com/bAxq5Lsl.jpg |
Re: Rear end out of a dune buggy It looks like a 37 to 40 rear and that it had 46 to 48 brakes ita was probably out of a 37 or 38 and had the mechanical brakes changed to juice
Also has the earlier style shape of the the torque tube |
Re: Rear end out of a dune buggy So that must be a 37-38 front axle?
Re: Rear end out of a dune buggy qmdv, Your 53" at the backing plate doesn't match your tape measure 481/2" at the spring hangers. Something funny there, so check this Street Rodder article and measure your rear end again.
http://goldengatev8.org/images/Stree..._magazine.html |
Not according to the pictures you posted. check your pictures and read the article. |
Re: Rear end out of a dune buggy Just read the article and it was very informative. And my bad. The 48 1/2 was at the spring perch holes of the rear end. I later measured the distance at the point of were the backing plates bolt up and that is 53 inches. The article tells me that it is a 42 to 48. The front and rear brakes were the later type hydraulic. And the front axle top spring perch holes were 40 3/4.
The engine was not a 59AB (but that could have been changed) Had a side shift trans. So now that I know it is all 42 to 48 I can put it all up for sale. Too heavy to ship so it will probably be pick up only |
Re: Rear end out of a dune buggy ford38v8-thats a great article, thanks for looking it up
Re: Rear end out of a dune buggy Front axle looks like a '42 up axle with that perch bolt spacing.
Re: Rear end out of a dune buggy 1 Attachment(s)
I was looking for that article. It was a pdf for a bit. Think I have it but... Thank you Some more stuff. |
Maybe... what do i know, best of luck duder seriously, Look up spring dimensions. but...
Re: Rear end out of a dune buggy 48-two holes-first year of tube shocks if i remember correctly, which is asking for a lot
Re: Rear end out of a dune buggy |
Re: Rear end out of a dune buggy 2 Attachment(s)
... Thank you pete
another fav |
Re: Rear end out of a dune buggy The 32 Highboy will be on the road in time for summer. How will a 75 year old guy look with "flattop boogie"
