Trans U-Joint nut torque specs Checked Van Pelt's site and did some other searches but can't find the torque specs for the nut that holds the front u-joint to the trans on my '39 pick up. Anyone know the numbers? Thanks.
Re: Trans U-Joint nut torque specs Was there one? I just make them good and tight with a drop of locktight.
Re: Trans U-Joint nut torque specs 3/8 unf, ht bolt,about 30 ft lbs ,seems right
Lawrie |
Re: Trans U-Joint nut torque specs Three white knuckles.
Re: Trans U-Joint nut torque specs I was figuring that goodntight was about right. Thanks.
Re: Trans U-Joint nut torque specs Don't forget that fat spacer washer.
Re: Trans U-Joint nut torque specs Quote:
