Extra water pump grease I was given a couple gallons of pennzoil #362 water pump grease. Is this stuff still relevant?
Re: Extra water pump grease Use regular wheel bearing grease in water pump.
Re: Extra water pump grease Speaking of water pump grease, should one use a different type? Also, wondering if the grease could pass into the water jack?
Re: Extra water pump grease Quote:
BTW, in the 10 years I've been running my restored water pump, I don't think I greased the rear bushing more than three times. and only checked the packing nut a couple times to see how tight it was. I keep it just lightly tightened. The rear bushing is still nice with no slop. |
Re: Extra water pump grease I always use waterproof Calcium Sulfonate base trailer bearing grease in the pump rear, but that's only because I always have several guns with different greases. Too much pumped in will surely gunk up your radiator, so be careful not to over-do it.
Re: Extra water pump grease The Model B water pump was similar to the Model A pump and in the 1932 Service Bulletins it states that the Model B and the V8 water pumps were designed to use pressure gun lubricants, and to avoid use of special water pump lubricants. The reason given was that water pump lubricants have a melting point higher than the maximum water temperature, which allows any surplus grease to enter the cooling system and block radiator tubes. I know that is 1932 era advice and may not be applicable today with modern lubricants. Maybe someone with knowledge of todays lubricants can give us an update.
