Is the correct rear wiring clip? early 28 phaeton RHD.
It has a few of these clips clipping the wire to the top of the lower flange down the right side. When I saw them , I thought they were just modern clips, but upon seeing an original style tail light stalk clip, maybe I should not be so careless with them? http://i86.photobucket.com/albums/k1...d/wireclip.jpg |
Re: Is the correct rear wiring clip? That looks correct to me. I installed some repro clips on a 1931 widebed they other day and those clips were a bit longer, which I'm sure isn't correct, but it may be all that is being manufactured right now.
Do you have the 2 clips for the arm to hold the wires for the drum tailliight? Of course they are a different shape than the frame clips. |
Re: Is the correct rear wiring clip? Tom , no clips on tail light stalk.
But I better look after the chassis clips if they are original. The wiring has been butchered with plastic , but these chassis clips were still there along with the remains of the original wiring tucked in behind the chassis at the brake cross shaft point. |
