1940 Deluxe coupe, cowl " water catch tray'' Greetings,
Writing from the Wet PNW, I've a 1940 Deluxe Coupe , I'm always looking to drive , most any weather. There a rubber gasket and a screen on top of the cowl opening. But no catch basin to prevent water pouring inside the car ! After washing my car when day this summer, I noticed the Carpeting blow. The cowl was wet. A quick glance up revealed, there is no drip tray, catch tray or whatever it's called, for any moisture or rain to collect and drain to the outside the interior. What are my options, car is painted, running , and otherwise complete. Thank to all who chime in ! jim |
Re: 1940 Deluxe coupe, cowl " water catch tray'' Quote:
A new seal, properly installed and a tight, properly adjusted cowl vent lid. |
Re: 1940 Deluxe coupe, cowl " water catch tray'' There is no tray or drain, the gasket fills the area below the lid edge. Ditto what Kube said above.
Re: 1940 Deluxe coupe, cowl " water catch tray'' 5 Attachment(s)
As has been mentioned, there is no interior cowl vent drip tray on a 40 Ford. After you install the new seal you can adjust how tight the cowl vent lid compresses against the gasket so as to prevent water from entering your interior. Also, be sure to install the new gasket with curved edge facing down. Also, once a year I wipe the top of the gasket with Armor-All to keep it pliable.
Re: 1940 Deluxe coupe, cowl " water catch tray'' Thank you , very much . Learn something new everyday. !
Re: 1940 Deluxe coupe, cowl " water catch tray'' Thank you !
Re: 1940 Deluxe coupe, cowl " water catch tray'' Thank you!
Re: 1940 Deluxe coupe, cowl " water catch tray'' Thank you All for responding..
Onward then .... |
Re: 1940 Deluxe coupe, cowl " water catch tray'' no fresh air in the rain... at least from the cowl. I learned that just now myself.
Re: 1940 Deluxe coupe, cowl " water catch tray'' My ‘41 was also leaking at the bottom edge of the windshield along with the cowl vent.
Re: 1940 Deluxe coupe, cowl " water catch tray'' A little heavy on the properly, but of the nine cars from the era of that lovely vent design, all shown the weakness of the seal. There is some range in quality of the replacement seals. I would regularly use lo-tack tape to seal the vents on the upper side to prevent any leakage. Give it the old properly try. Good Luck: Fred A
Re: 1940 Deluxe coupe, cowl " water catch tray'' 3 Attachment(s)
Hmmm, this is interesting because my 1937 passenger car does have a water catch tray designed around the perimeter of the vent screen and there is a drain tube at the front of the tray that drains any collected water into the engine compartment. The first photo shows the location of the drain hole, with a drill bit stuck in it. The second photo shows the location of the drain nipple in the engine compartment and the third photo shows the drain nipple without the drill bit. I am surprised this feature was not included in the 1940 models being discussed.
Note there is a hose bead on this nipple, which seems to indicate that a hose may have been installed originally to drain the water away from the engine. |
Hi Zeke, I had a '37 Ford coupe many-many years ago, and I remember replacing that worn-out cowl gasket ,to stop the water from leaking in. There was NO little drain like you show. The NEW gasket solved the leak. . |
Re: 1940 Deluxe coupe, cowl " water catch tray'' My car is a deluxe coupe that has a body number tag, so I believe the body was from a supplier. Perhaps my water tray was unique to that supplier. I don’t know any other reason my 37 would have this feature and others wouldn’t.
Re: 1940 Deluxe coupe, cowl " water catch tray'' Zeke, that is Not a water tray. It is the tray for the Gasket to set into.
Someone has put in that Little drain... Do a search for a "cowl gasket" for your car. I think '37 to '48 are all the same size. . |
Re: 1940 Deluxe coupe, cowl " water catch tray'' My 37 has the little drain tube, it is Canadian made, NZ assembled car. Others that I have seen or owned all had one as well.
Re: 1940 Deluxe coupe, cowl " water catch tray'' The might look closed but you have to give the lever a good tug to make sure it is closed .if it leaks you need a new rubber seal vent
Re: 1940 Deluxe coupe, cowl " water catch tray'' 2 Attachment(s)
I don't see any indication that someone added that drain after the car was manufactured in 1937. |
https://www.fordbarn.com/forum/attac...0&d=1703038385 |
