Horn wires Hi all.
I swapped over to 12V and bought the horn reducer that Lang’s sells. It says unplug the yellow wire and plug that into the reducer. Problem is I removed both blue and yellow wires from the horn and do not remember which ones went where on the horn. Does it matter? If so what wire color is closest to the radiator? My horn is an original spartan. |
Re: Horn wires Doesn't matter.
Re: Horn wires For the correct answer see post #2
