Original VS reproduction 1929 Roadster Tried to replace my gas guage and the reproduction outer nut is very poor fit. My original nut threads very smoothly but the repo is so loose I'm afraid to try to tighten it up.
My original http://i1291.photobucket.com/albums/...s8gwemaas.jpeg The reproduction http://i1291.photobucket.com/albums/...shkqcreyb.jpeg Video http://vid1291.photobucket.com/album...psefgiq2l8.mp4 |
Re: Original VS reproduction 1929 Roadster Why not use the old one on it then ? Wayne
Re: Original VS reproduction 1929 Roadster Think restore not replace. You have a good original, just have it re Nickel plated. That Chrome repop would look wrong even if the thread was correct.
Re: Original VS reproduction 1929 Roadster The outer repo nut is an issue as you found out... Do not use it as the threads are off..I tried more than one then sent them back for a refund
Re: Original VS reproduction 1929 Roadster Quote:
Re: Original VS reproduction 1929 Roadster The bad one you sent back is turned around and then sent out to another unsuspecting customer.
