Tudor top Does the foam on the top cover only the chicken wire or does it continue over the sheet metal to just above the rain gutter. Thought I remember seeing top installation instructions somewhere but cannot remember what book they were in.
Re: Tudor top try mac's . I do believe it goes to the gutters . I did one years ago but no memory ..... steve
Re: Tudor top Cotton padding,,,,,,foam was not used ,,, it covers only the wire in all directions
Anti squeak on the bows http://i684.photobucket.com/albums/v...psfecdadc6.jpg Denim material http://i684.photobucket.com/albums/v...psee663d42.jpg Cotton padding http://i684.photobucket.com/albums/v...ps6620fb0f.jpg |
Re: Tudor top What year Tudor?
As Mitch said, don't use foam. It won't look right, and it will break down with heat and time. |
Re: Tudor top Also, do not apply the cotton batting directly over the chicken wire, it will work through the wire, and if mice get into the headliner they will have a field day with the cotton. Use a layer of duck cloth under the cotton. You can get it at a fabric store.
A good set of instructions can be found on Marco's site: http://www.abarnyard.com/workshop/roofinstall-1.htm |
