'40 Ford Conv. door latch springs Does anyone know where I can purchase CORRECT door latch springs? I am attempting to rebuild my latches but can't seem to find any that are correct.
Thanks in advance... |
Re: '40 Ford Conv. door latch springs Have you tried Restoration Specialties out of Ohio.
Their catalog has lots and lots of stuff for doors. And they state: If you have a sample of what you are looking for, contact us so we can check our inventory. Found them at Hershey this year. |
Re: '40 Ford Conv. door latch springs Quote:
Re: '40 Ford Conv. door latch springs 2 Attachment(s)
Here's a photo of both the upper and lower springs. Ultimately, I'll need two of each. |
Re: '40 Ford Conv. door latch springs Ran into this when I did mine.Ordered a set from Drake,and other vendors and none were for the conv.They all aid it was for it but not.Found a set from a scrape hinge one a man had.Heny made the conv different.
Re: '40 Ford Conv. door latch springs 1 Attachment(s)
Re: '40 Ford Conv. door latch springs The springs can be found in assortments, but most times not by listings, I solved my problems on my 36 ----will Dennis Carpenter solved them, in their "NOS" sales tent at Hershey I found NOS latches one year for little more than the cost of springs ---the 36-39 conv seadn latches are the same as 40 conv with the exception of the linkage rod
Re: '40 Ford Conv. door latch springs Fabricating springs is a challenge but sometimes a necessity if you can't find good or NOS stuff. I've fabricated different types of springs for gun internal parts so I know how difficult it can be. If you find one that is close in size and load capability, that would save some time in fabrication or modification. I sure can't help with finding any you need.
Re: '40 Ford Conv. door latch springs I went through a couple of boxes of new springs I have, but nothing for a '40 convertible - sorry
Hey, Kube, I will look again tomorrow and see if there are any other springs up over the other garage.
Found these but their to early. BILL |
