Door windows How do you get the glass out of the 28 Tudor doors? Got the rear glass out with no problem.
Re: Door windows did you remove the top door plates held in by the 3 screws....
the glass will then slide / lift right out sometimes the screws can be seized somewhat i use an impact driver now and then but also had them snap not a big deal.. i think some of them were brass |
Re: Door windows I've had to heat the 3 screws for the top plate 2 or 3 times before I could get them out. I also like to use the impact driver Mitch mentioned.
Re: Door windows Thanks guys - both windows are now out.
John |
