NAPA pt # Unilite points Anybody have the NAPA # for Mallory Unilite replacement points ???
Charlie ny |
Re: NAPA pt # Unilite points Quote:
https://www.google.com/search?sxsrf=...w=1280&bih=881 |
Otherwise ( pn 25042) from Speedway,Summit,Jegs etc for point type dist. |
Re: NAPA pt # Unilite points 5 Attachment(s)
Yes, I was wondering about that also since Unilites don't use points. Perhaps he wants to convert his Unilite back to a "points" distributer. If so, the cam lobe, condenser and rotor are needed. Cam lobe must be correctly indexed on shaft (see little dot) and installed gently. Here's a Mallory dual point that was converted to a Unilite and then converted back to points. It has mechanical advance.
Re: NAPA pt # Unilite points As I posted on the other "Charlie ny" thread, Echlin CS2300 points will substitute for Mallory 25042.
Re: NAPA pt # Unilite points Thanks guys, much appreciated.
Charlie ny |
