1939 deluxe headlight switch Seated in the driver's seat can someone please let me know what the control dial positions are for turning from left to right?
Thanks in advance...Frank. |
Re: 1939 deluxe headlight switch turn left for headlights or right for park off should be centered high / low on floor i think if its the same as a mercury
Re: 1939 deluxe headlight switch It's been awhile since I had one of these, but isn't it one position counterclockwise for low beams and two positions counter-clockwise for high beams?
Re: 1939 deluxe headlight switch Tubman, by 39 Ford (started in 38) had gone to a floor hi/lo headlight switch. The column switch was just Parking lights and Headlights.
Re: 1939 deluxe headlight switch OK; I had a '36.
Re: 1939 deluxe headlight switch Ya, I think 36 and 37 were fairly similar, change started in 38 and by 40 the light control switch was on the dash.
Re: 1939 deluxe headlight switch Thank you for the responses...been a great help.
