38Frame Need advice ,we have a replacement frame to use in a 38 club convt. the frame SN is 18 2015141 it looks the same as the 38 but there is a lot of differences one noticablle one is the rear shocks originally mounted to the side of the frame rail where as the 38 shocks mount to the bottom of the rail what year might it be can one tell from the SN. Thanks Johnny.
Re: 38Frame Rear shocks mount on the underside of the rails and front shocks mount on the side.
Re: 38Frame Quote:
Re: 38Frame If you have the original 38 frame, there are several additional braces and mounts specific to open cars you will need if you use a closed car frame.
Re: 38Frame Thanks Lawson for the infor. and to JimTN yes we have all the necessary add ons also changed the front crossmember The old frame was completly 'eat out '.Thanks all Johnny
