38 ford pickup Was wondering if what exhaust manifolds will fit my 38 pickup with a1950 flathead motor stock style or headers thanks Tom
Re: 38 ford pickup The easiest is to use those that were stock on your '38 thru 59 series engine. Clears the steering box and you can run duals or stock. You can use the 8BA manifolds but with the front crossover this complicates things.
Re: 38 ford pickup Will car manifold work on my 38 ford pickup or pickup manifold works only
Re: 38 ford pickup Car manifolds will work.
Re: 38 ford pickup Looking for a dash window molding for a 38 PU for a friend.
