Looking to identify parts and value 3 Attachment(s)
Looking to identify year(s) and value of door felt trim metal. 14 3/4” inch tall. Thinking Standard model years?
Looking to identify and value of Deck Lid hinges, they are shorter than 39-40 Fords. Thank You Joe |
Re: Looking to identify parts and value Quote:
The lid supports are pretty much worthless, maybe $10 or so IF they will support the lid. |
Re: Looking to identify parts and value The metal trim is 1/8” wide. I’m just saying for Standard cars? as the front bottom part is not as wide as in my 39 Deluxe. The measurements are the same as I have in my car, a Deluxe Coupe. ( 14 3/4” tall X 31” long. ) I’m not familiar with the height and length of a driver side door felt upholstery trim on a “ sedan “ reason for asking.
I think the deck lid hinges has value, ( repop springs can be purchased if hinges don’t hold decklid up ) especially if they don’t make this type in repop. I’m not sure how a 37-38 Ford Coupe deck lid hinge looks like, if it’s manual lock, if so then not sure where these go or even what manufacturer of auto. If the 37-38 Ford Coupe uses spring hinge types ( like the 39-40 and later ) thinking maybe they go on those year cars? As the decklid is smaller than the 39-40 so thinking the hinges will be smaller, which they are compared to the 39-40. This one looks to have the original factory color of a very dark blue. I’ve owned many parts for 51 years, ( as it came with my 39 which I purchased it in 1970 and still own ) and needing to prioritize the parts that I’m not familiar with for future sale. It’s not like I’m a young kid anymore. Thank You |
Re: Looking to identify parts and value They 37 Ford coupe deck lid had a manual mechanism to lock it upright (not something with springs).
Re: Looking to identify parts and value 1 Attachment(s)
Re: Looking to identify parts and value Nice looking 39 coupe by the way,Bazooka !
A similar but longer support, p/n 78-7068970-B, was used on sedans. You might checkout the Automotive Trimming and Supplies catalog, page 13, for more details. I don't have a copy of that publication yet. |
38 deluxe >>> 39 standard 39 deluxe >>> 40 standard If they fit '40 standard then they have a better chance of fitting 39 deluxe than a 39 standard?? |
Just found these in my shop. They came off '38 deluxe fordor. Pic is of front passenger door(right). 14 3/4" tall x 31" wide. Appears to be the same in your photo.
https://www.fordbarn.com/forum/attac...1&d=1613852384 |
Re: Looking to identify parts and value 2 Attachment(s)
Re: Looking to identify parts and value 3 Attachment(s)
Deluxe 39 and 40 see attached.
See attached.
See attached.
Re: Looking to identify parts and value Yes, mine looks like the 39/40 Deluxe Coupe as you show, as long as it’s 31” long and 14 3/4” tall, which guessing it is,..Thank You
Zeke3
Looked long and hard, this matches what I have, the plate with the two holes that hook to the decklid matches mine, and has a bend in the arm like mine. Mine is as wide ( plate with two holes ) and the plate angle is exactly the same. Says it’s for 41-48 Ford Tudor & Fordor Sedan & 1939-48 Mercury, so says C W Moss Thank You for your help |
Re: Looking to identify parts and value Those are great photos mercurycyclone. Thank you for sharing. Nice to be able to see side to side comparisons.
Will and Joe 38 Deluxe seems closer to 39 - 40 Deluxe and 38 Standard I think would be closer to 37 Ford Deluxe and Standard.
I have attached photos and measurements of 39 - 40 deluxe coupe. |
Re: Looking to identify parts and value I should have said I attached photos and measurements of the 39 and 40 Ford Deluxe & Standard Coupe door trim.
Mine is EXACTLY 31” long, not 31 3/4” wide as you reference for the 39-40 Ford Deluxe, and probably the Standards are also ( 31 3/4” long ) for those two years. Thinking Will D photo and measurements are more correct, but even then in his photo it still does not look exactly 31” long, as the tape measurement looks a tad off on both ends. Maybe not thou? He says that piece came off a 38 Deluxe Fordor, I’m sure it fits other years models also. Doubt it’s a one year specific model knock off. https://www.fordbarn.com/forum/attac...3&d=1613852381 I’m just trying to ID part for future sale. Thanks for everyone help,.. |
Thanks again for your effort Joe |
| All times are GMT -5. The time now is 01:46 PM. |
