01-05-2011, 11:26 PM | #1 |
Clinch Nut Installation
How are the D shaped clinch nuts installed?
I need to replace several 10-32 Clinch nuts in the top of the door of my 1928 Coupe. The nuts are removed and I have new clinch nuts, but no idea how to get them to "clinch".
GG Allenwrench- |
01-06-2011, 05:33 AM | #2 |
Re: Clinch Nut Installation
We buck then in with a rivet gun and a flush rivet tool, ....or in areas where we cannot get directly behind it, we will TIG weld them in on the front side.
01-06-2011, 08:00 AM | #3 | |
Brent doing this now do you install a bolt and then tig, I have a mig wanted to spot weld then dress the area, my fear is i will melt the threads in the d nut thanks al |
01-06-2011, 09:58 AM | #4 |
It does not take much to weld them in place. If your MIG is set right and you use an autodarken helmet you should be fine. I put a few in with a mig as I could not set them with a hammer. I did not get a TIG till much later.
Keep in mind that they are covered on the face. They do not have to be picture perfect to function and they are always covered. |
01-06-2011, 02:40 PM | #5 |
Thanks for all the replies guys, I now have direction
GG Allenwrench- |
01-06-2011, 08:27 PM | #6 |
I used a MIG welder, just 2 or three little tack welds on each. Some photos: http://www.dougbraun.com/model_a_gal...g2_itemId=3215 (yes, some of the spot welds are absymal...) Doug
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
01-07-2011, 06:44 AM | #7 |
This may sound stupid but make sure they are steel.
I got some that turned out to be plated brass or bronze and melted as soon as I hit them with the Tig, I ended up just soldering them in.
Current project an A-V8 Roadster Pickup! |
01-10-2011, 12:15 PM | #8 |
Thanks for the pic's Doug. Ted, thanks for the heads up.
GG Allenwrench- |
