12-29-2010, 06:37 PM | #1 |
Model A Quail
I believe I have found an original Model ‘A’ Quail hood ornament. I went on the web to research it and found nothing. I was hoping some Ford Barners could post pictures of their original quails and share their knowledge on what is original and what is not.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
12-29-2010, 08:53 PM | #2 |
Re: Model A Quail
If it's a 29, it would be VERY different. If it's a 30-31, find someone with a definite repo and compare. They were pot metal so there are not many left.
12-29-2010, 09:26 PM | #3 |
Re: Model A Quail
The Restorer did an article on them. Someone will dial in I'm sure.
12-29-2010, 09:54 PM | #4 |
Re: Model A Quail
originals have much sharper detail than the repros available now. On the underside of the top cap, look for the STANCO logo in the casting. The patent number is stamped in the stainless steel inner liner of the top cap as well as the words, "other patents pending".
12-29-2010, 10:24 PM | #5 |
Re: Model A Quail
If you have access to The Restorer (TR) and or Model A News (MAN), then here is where you will find an abundance of information on it:
A-18385-AR, B: Radiator cap and ornament (Flying Quail) “On the Road”: MAN/40/3/9-10 (1993) “On the Hill”: MAN/48/6/15-16 (2001) “Quail Radiator Caps”: MAN/49/6/10-13 (2002) “Ford’s Hoosier Mascot…(History of the Flying Quail)”: TR/4/6/6-13 (1960) “Schematic Drawing”: TR/14/2/Back Page (1969) “TIP…Securing Radiator Ornaments”: TR/29/6/16 (1985)*4 “TIP…Holder Bar for 1930-31 Radiator Ornament”: TR/32/2/32-33 (1987)*4 “Ford’s Hoosier Mascot…(History of the Flying Quail, Reprint)”: TR/53/5/8-12 (2009) |
12-30-2010, 03:31 AM | #6 |
Registered User
Re: Model A Quail
here are a few original quails the first 2 are 30-31 stancos Stant Manf Co the next one is a 29 Stanco,this one is missing the base,it screws on the last two are Jarvis 29 caps the 30-31s are currently reproduced and they are quite well done,the detail is not as sharp whereas the 29s are not being reproduced and are really different from the 30-31 and also different from manufacturer to manufacturer i also find the Jarvis tend to be of an inferior base metal ,and tend to spall tom |
12-30-2010, 09:32 AM | #7 |
Re: Model A Quail
I seem to recall they sell for over $1000 on ebay regularly.
Perhaps someone has better information. |
01-15-2011, 05:33 PM | #8 |
Re: Model A Quail
The bottom of the quail is stamped "Glendale, Ct-Greenland Co. 4". Any additional information would be appreciated. My book collection is slowly increasing, eventually I hope to be able to collect the back issues of the two magazines. Thanks Paul
01-15-2011, 05:56 PM | #9 |
Re: Model A Quail
I believe Greenland is an older repro.
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
01-15-2011, 06:20 PM | #10 |
Re: Model A Quail
Sheldon Greenland's old parts company?
01-16-2011, 12:30 AM | #11 |
Registered User
Re: Model A Quail
yes greenland is one of the first reproductions
probably from the 70s,they used to sell for $19 |
04-15-2011, 04:51 PM | #12 |
Re: Model A Quail
Tom(mot) posted some great quail pics last year(very much appreciated Tom), but I still can't figure out the year of my quail(bird only unfortunately). Looks like '29, but can someone confirm? Thanks. Bruce.
04-15-2011, 05:36 PM | #13 |
Re: Model A Quail
Here is an ad from 1967 for the reproduction quail radiator cap.
Bob |
04-16-2011, 12:27 PM | #14 |
Re: Model A Quail
Tom-Here's a shot of the underneath. Thanks for your help.
04-16-2011, 12:32 PM | #15 |
Registered User
Re: Model A Quail
1929 Stanco
04-17-2011, 03:25 PM | #16 |
Re: Model A Quail
Hi,
about a year ago i purchased a motormeter . After i took it home i found it to be nos. It was still in it,s original box and along with the meter, there is a small phamplet dersribing other products the box itself is somewhat brittle due to age. After seeng where someone saw on on ebay for $1000.00 i wonder if the one i have is an original or not. After i get over this flu-like cold i will describe it better. Big al |
04-17-2011, 03:41 PM | #17 |
Re: Model A Quail
Hi,
after reading my post i realized my purchase was not a quail sorry for the confusion big al |
04-17-2011, 04:45 PM | #18 |
Re: Model A Quail
Wow, those are cool.
ESTRANGED CC |
06-17-2011, 08:16 PM | #19 |
Re: Model A Quail
I am having trouble with my quail cap on my '28 roadster. In order to avoid interference between the cap hinge and the hood panels, I have had to move the radiator forward. When I do this, the panel hinge shaft is out of it's hold-down brackets. Some have recommended that I move the cap hinge to the side, but am unable to do so. Recommendations?
Joe/Ct "The older I get, the better I was" |
06-18-2011, 12:49 AM | #20 |
Re: Model A Quail
Not sure I completely understand your problem - a picture would help. Try putting a thin stainless washer/spacer at the radiator end of the hood shaft/rod (on the rod) where the rod enters the front hold-down bracket. The washer sits between the hold-down bracket and the first hood panel hinge and will move the hood panels back. I had to do this modification last weekend because the edge of the hood panels were hitting the tail of my quail. One member in our club uses a slice cut out of stainless steel tubing.
