11-23-2017, 02:00 PM | #1 |
Throttle shaft ??bush or go oversize
During my carb. rebuild I noticed that the throttle shaft is a bit loose in the holes. Not super bad but you can feel a little there. Which works best, drill and install bushings to bring it back to factory specs. or drill and install an oversize shaft?
11-23-2017, 02:28 PM | #2 |
Re: Throttle shaft ??bush or go oversize
There is a third option: Apply a little solder to the shaft. I use lead-free solder which is harder. Not just a farmer fix, do a search here on fordbarn for Rex Reheis.
11-23-2017, 03:29 PM | #3 |
The shaft has to be very sloppy in the housing for it to cause a problem. I think many quite serviceable bodies/shafts are messed with unnecessarily. By the time it should be done, a little JB weld on the shaft and filed to fit will do the job fine. If you must do it, I don't think it matters much whether you used an oversized shaft or rebush the body.
11-23-2017, 03:41 PM | #4 |
I find it much easier to drill and fit oversize shaft rather than the palaver of drilling and re-bushing ( in fact I can see no reason to re-bush now that oversize shafts are available). The body has to be drilled out a bigger hole to accommodate the bushings than a new o/s shaft takes so from a preserving metal point of view o/s shafts are better. Agree with Ian in #2 try solder if you don't want to send any money at all on new parts!
11-23-2017, 04:08 PM | #5 |
solder easy,and dosen't have to be all the way around. as per Rex Thanks
www.whidbeymodelaclub.com |
11-23-2017, 06:42 PM | #6 |
11-23-2017, 06:49 PM | #7 |
Isn't there something about air leakage from a sloppy fitting shaft and good carburetion?
Good enough.. Isn't. |
11-23-2017, 07:31 PM | #8 |
you could solder the opening and drill that to get a tight fit. or fill it and drill it.
11-24-2017, 03:45 AM | #9 |
Yes a sloppy shaft can allow air air to be drawn through it ( especially at idle) making the mix weaker, having said that I'll add ....if it runs OK it is Ok!
11-24-2017, 09:20 AM | #10 | |
One note of caution is you really do not want to drill the housing bore but instead you need to ream it to size. I actually have modified a large angle plate where I can bolt the upper house to the angle plate to index it vertically, and then it is easy to ream it with the Mill if your head is trammed in correctly. |
11-24-2017, 12:24 PM | #11 |
Good advice Brent! How about using a oversized shaft and turn it down to fit the body?
11-24-2017, 01:40 PM | #12 |
x2 to what Brent said. Repairing or replacing sloppy throttle shafts goes a long way towards reducing stalling at stops.
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
11-24-2017, 07:26 PM | #13 |
X3 to what Brent said! Use a reamer! HA! Where do you find a reamer that size? I was getting .267-.269 . I went out in the shop (colder than a witch's underwear) and I was shaking a little bit. And I was trying measure with a vernier. In any event, I would normally tell someone to ream the bore for trueness, trying to drill it often produces a three sided hole. If I'm any where near to correct on that shaft size, it's not a standard fractional size so I don't know what you would ream it with. 1/4' = .250 1/64 over 1/4 (17/64) or .265 9/32 or 1/32 over is .281. There might be a letter size reamer. I don't know. I've probably got the shaft size wrong I was shaking so much, it should be verified.
And old toolmakers trick, use a ball from a ball bearing (about 3/8 to 1/2 in, dia.) seat it on the hole and give it a sharp rap. This is called "staking" and will "tighten" a bore. Many a loose bearing seat has been been "Fixed" using this method. Good luck! Terry |
11-25-2017, 11:26 AM | #14 |
Bratton's catalogue says the standard shaft is 9/32" and the oversize shaft is 19/64"
11-25-2017, 02:30 PM | #15 |
got drill press it is easy to install bushing....
Thread Tools | |
Display Modes | |
