Old 11-06-2010, 03:57 PM   #1
John LaVoy
John LaVoy's Avatar
Default Open driveline on Model A
One time at the North West regional I saw a fellow selling kits to convert the Model A to an open driveline. Does anyone know his name?
Thanks,
John
John LaVoy is offline   Reply With Quote
Old 11-06-2010, 04:00 PM   #2
Chris Haynes
Chris Haynes's Avatar
Default Re: Open driveline on Model A
More importantly why?
Speed costs money. How fast do you want to go?
AAA Member
Costo Member
I can't Re Member
Chris Haynes is offline   Reply With Quote
Old 11-06-2010, 04:31 PM   #3
John LaVoy
John LaVoy's Avatar
Why not? I plan on using an automatic transmission and it will make the installation easier.
Old 11-06-2010, 04:45 PM   #4
Chris Haynes
Perhaps a question that should be asked in the Hot Rod section.
AAA Member
Costo Member
I can't Re Member
Old 11-06-2010, 05:05 PM   #5
JoeWay
JoeWay's Avatar
Speedway has one.
http://www.speedwaymotors.com/Ford-O...-Kit,3770.html
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 11-06-2010, 05:05 PM   #6
john in illinois
john in illinois's Avatar
The conversion to a 5 speed Muncie transmission requires an open driveline.
The people that build the kits might be able to help with just the drive line.
LINKS http://munciekokomo.citysearch.com/p...torations.html
http://lainefamily.com/ModelAFiles/ModelAT5.htm
john in illinois is offline   Reply With Quote
Old 11-06-2010, 05:39 PM   #7
quickchange
quickchange's Avatar
John, Hi from NZ, Hotrod works & speedway motors do one, Some smaller tractors use a 6 spline PTO coupler for drive to to impliments, seen them used , In order to create a cheap seal on orig rear bango you can cut the end of orig torque tube & fit seal inside, , Hope this helps, Cheers Derek.
quickchange is offline   Reply With Quote
Old 11-06-2010, 06:21 PM   #8
Cool Hand Lurker
Cool Hand Lurker's Avatar
I have not tried it, but I have heard that the F-1 pickup pinion shaft will interchange. With that you
can put on an external U-Joint. And I don't care why you are doing it.
Cool Hand Lurker is offline   Reply With Quote
Old 11-06-2010, 06:25 PM   #9
zzlegend
zzlegend's Avatar
John, i dont know if this will help but here is another site. Mark.
http://www.flat-o.com/carproducts/flatomatic.htm
zzlegend is offline   Reply With Quote
Old 11-06-2010, 07:54 PM   #10
denis4x4
denis4x4's Avatar
Steve Becker just completed an open drive line A rear end for me. Bert's Model A in Denver 800/321-1931
denis4x4 is offline   Reply With Quote
Old 11-06-2010, 11:02 PM   #11
callcoy
John;
Remember you can contact Art Moore down in Upland, I believe he has 5 "A"'s with open drive lines, auto trans adaptors also, call him at 909-982-7790, you can tell him I sent you!
Steve - Santa Rosa
callcoy is offline   Reply With Quote
Old 11-07-2010, 07:02 AM   #12
James Rogers
James Rogers's Avatar
I have seen this many times before. Someone asks a question about a mod that many are interested in and another poster tries to direct him/her to the hot rod board like they are in the wrong place. I wonder why this is when not a soul even mentioned the hot rod board when this string came up, http://www.fordbarn.com/forum/showthread.php?t=16638 .
Kind of a one sided way of looking at things. I don't know why some are singled out to be berated and pushed toward the hot rod board and some are ignored when they are doing something that is obviously hot rod related.
Comments?
Old 11-07-2010, 07:33 AM   #13
brokenspoke
The torque tube is an important part of the rear....If its removed another form of locating the rear end is needed to keep the rear end from twisting....
brokenspoke is offline   Reply With Quote
Old 11-07-2010, 08:07 AM   #14
Earle
Earle's Avatar
Most of this was over my head. I hadn't heard this kind of Model A "modification" discussed before. What are the advantages of removing the torque tube? And like brokenspoke says, aren't you now allowing the whole rear end to "float" more and sending thrust and rear axle twisting/torque loads into areas where they weren't intended by design to go?
How do the benefits outway the risks?
Forgive the time-worn cliche, but Henry designed it that way - with a torque tube - for a reason! (in MOST cases, anyway... - when he wasn't doing things just to save a penny). He could have saved a lot of time and pennies by eliminating the torque tube! - but he didn't!
Earle
Earle is offline   Reply With Quote
Old 11-07-2010, 09:21 AM   #15
John LaVoy
John LaVoy's Avatar
The speedway motors looks like a good way to go. Thanks everyone for the input. Just for the record I have some subscribers that have requested we look into installing an automatic transmission because of health reasons they can not drive a manual transmission car and want to continue in the Model A hobby.
Old 11-07-2010, 10:38 AM   #16
denis4x4
denis4x4's Avatar
John
I'm working on my second A without a torque tube. The wish bones are easily modified with a 1/4" by 1" strap welded on both edges to the bottom seam of the wishbones. This was necessary to install a T-5 transmission. There is another piece that bolts to the crossmember where the shifter tower is located. Note the master cylinder location using the stock cross piece.
I often wonder if Edsel got a ration from the old man when made modifications to his Fords?
Old 11-07-2010, 10:41 AM   #17
1931 flamingo
1931 flamingo's Avatar
Earle: Many people have(or are) converting to open drive when replacing original transmission with 3 spd synchro out of late model ford trucks (w? o/drive) and many have gone to 5 speeds out of chevys. Yes you need to stabilize the rear end, either with a 3 or 4 pt connection to frame or "splitting" the rear wishbones and mount to frame. Actually the orig A wishbones are a little week so modifications are necessary.
Paul in CT
Old 11-07-2010, 11:06 AM   #18
Tom Wesenberg
Tom Wesenberg's Avatar
Check with Steve at Bert's in Denver. I seem to remember he mentioned doing a couple of automatic changes for customers that could no longer shift. They used MoPar automatic transmisions. I don't remember that they had to have an open driveshaft, but don't know about that for sure.
Tom Wesenberg is online now   Reply With Quote
Old 11-07-2010, 12:06 PM   #19
Logan
Logan's Avatar
are you going to use a stock engine? or hopped up model a flathead? Ive wondered if any one was running automatics, but had never seen one with a model a engine before.
Cowtown A's
Logan is offline   Reply With Quote
Old 11-07-2010, 11:43 PM   #20
callcoy
Sometimes we say things without knowing all the facts. I have been supplying product and service to individuals with disabilities for close to 30 years. Thru my shop thousands of people can now get around, report to work, cruise/tour with their friends and etc. And for those that are able to drive, an auto trans is their salvation. Previously I covered hand controls and manual transmissions so I wont bore you with those details.
My wife and I have had personal "mechanical" problems that has required modifications to our yet to be completed Panel Delivery. Without these non-standard additions we will not be out there with our friends. The addition of a automatic transmission may make it possible for one of ours to continue to drive and enjoy their Model A. Lets encourage them to do what ever they need to continue to be with us!
Steve - Santa Rosa
Thread Tools
Display Modes
