10-14-2022, 06:45 PM | #1 |
Radiator steams after short drive.
I'm the proud owner of a '29 roadster for all of 2 weeks! Much to learn! Under the hood looks very stock. A week ago I opened the Flying Quail radiator cap to check the coolant level. I could see a metal plate a few inches down. No coolant covering it. So I added some Prestone. Went for a drive of maybe a mile and a half. Parked it in my driveway and turned off the engine. Quite a bit of coolant came out the overflow tube. Quite hot. I have not added any more coolant since. Went for a drive today of maybe 2 miles. Parked the car and turned off the motor. Lots of steam coming out of the overflow tube.
- Is the Model A radiator pressurized? - Is this normal? I've read here a Model A radiator will find the level it likes. - Is the Quail radiator cap doing its job? I don't see a gasket on it. I'm afraid right now of driving it and possibly overheating it. I've been looking at Mikes Affordable and I like the idea of the oil filter kit. Anyone familiar with it? Is it good? The gas line coming out of the firewall goes through a brass bulb looking thing. Is that a filter? - Tips on winterizing? I have filled the gas tank and added stabilizer. Thank you all for any much needed advice! - Jim |
10-14-2022, 09:01 PM | #2 |
Re: Radiator steams after short drive.
Excess coolant will be expelled but steam is not normal. Several things can cause the car to run hot:
The radiator and engine need to be flushed. Some detergent will get rid of any grease scum and vinegar will help clean out the rust. The radiator needs to be replaced. The ignition is not set correctly. The fuel/air ratio is not correct. The radiator cap should have a gasket but not having one will not make the car run hot. Your radiator is open to atmospheric pressure, not pressurized. I have the glass bulb on my car but I think the brass one is also a sediment trap like the glass one. Heavy particles will settle out of the gasoline and fall to the bottom of the trap. It should also have a screen at the top to further filter out stuff.
10-14-2022, 09:58 PM | #3 |
The Model A radiator and cooling system is not pressurized.
10-15-2022, 01:46 AM | #4 | |
10-15-2022, 05:06 AM | #5 | |
10-15-2022, 07:57 AM | #6 |
Funny how when I test drove it before buying it this problem did not appear. - Jim |
10-15-2022, 07:58 AM | #7 |
If it was a blown head gasket would I see seeping around the head? The head / engine are dry.
Thanks |
10-15-2022, 09:20 AM | #8 |
There can be an internal leak in the head gasket that would not be seen on the outside. There can also be a crack. The test is to take your fan belt off and fill the radiator to the top. Run the engine and see if there are any bubbles coming up to the top of the coolant. Also see if there is steam out the exhaust pipe or water in the oil.
Your plan to flush the radiator is a good one.
10-15-2022, 09:21 AM | #9 |
How are you adjusting the timing, the lever on the left side of the steering wheel? Up to start then down a couple clicks for warning up, down about halfway for normal driving, all the way down for highway driving, move the lever up a few clicks if you hear or feel knocking
10-15-2022, 10:02 AM | #10 |
All the suggestions about timing, head gasket, cracks etc. are valid. But 9 times out of 10 it is a clogged radiator that causes overheating. Pull the radiator and bring it to a radiator shop to be rodded out.
10-15-2022, 12:25 PM | #11 |
The radiator could also be one of those Sears ones...
10-15-2022, 12:48 PM | #12 |
Make absolutely sure that you are advancing the AFTER she starts. Many new owners don't know that this is model A timing and should be set with the RPM and the ear If not, she will over heat . Next Don't over fill. Fill up to the bass plate and no more. Is the car losing coolant? Take it out for a few more runs and see how much it's down (Below the plate) Check your exhaust for a lot of condensate (white steam) after it's hot. Try to figure out exactly what's going on before you start wrenching. It may be nothing or it may be serious.
Terry |
10-15-2022, 01:57 PM | #13 | |
Also - don't run with the fuel mixture too lean (learned that one the hard way!); for my Model, about a 1/4 turn open is just about right most of the time. |
10-15-2022, 05:24 PM | #14 |
Mikes filter kits are great, I have a few of them.
If you fill the radiator to the top it is very common for the car to expel it out the overflow tube. Let it burp it out and leave it alone. Don't keep filling it. Many times a head gasket will slowly let go just enough internally suck out some water as you are driving and you will not see and drips in the engine bay. i am not saying you have a bad gasket, I am just saying. Winterizing, get yourself a cheap antifreeze tester Wallmart, Amazon, NAPA etc. If you use the concentrate you will be able to get the antifreeze to a good for -40 below. The 50/50 mix will not go that low. |
10-15-2022, 07:18 PM | #15 |
Yes, i move the spark lever all the way up to start and then move down when running.
I think I found the problem. It had been masked by all of the steam coming out of the overflow tube. Today I filled the radiator all the way up with water. started the car and opened the hood and looked all around while it idled. What do you know, coolant seeping out of the water hose where it goes into the block. Wow! That simple. I tightened the clamp quite a bit. All of the clamps needed and got tightened. I let it run for a while and it looks like that was it. I'm going to replace the hoses and clamps because they look old. Appreciate the tips. Would like to hear what you do to winterize your A. Thanks. |
10-15-2022, 07:23 PM | #16 |
For not a ton of money you can add a temp gauge to really see what the coolant temp is doing. I always thought my radiator was marginal. Added a temp gauge and found it runs in the 140-150 range. You might not have much of a problem other than overfilling.
11-05-2022, 07:56 PM | #17 |
So I put on new hoses, clamps, water pipe. New graphite packing on the water pump. Flushed water through system., Drained. Filled it with white vinegar and drove it around. Let it sit overnight. Drained it. Very rusty looking water. Filled with water. drove it around. Let it cool. Drained it. Did this flush process with water about 8 times. Water now comes out pretty clean.
After driving car while its idling I check it with an Infrared Thermometer. Upper radiator about 200 degress. Radiator gets cooler as I move down. When I turn off the engine the temp goes up. Tried the water test. Took off the bottom hose. Stuffed a rag in the lower radiator opening. Filled the radiator with water. Pulled rag out. Water was coming out at a decent volume for about 8 seconds. From what I've read this is not good. Radiator has white stains on front but doesn't leak. Do I need a new radiator? |
11-05-2022, 08:44 PM | #18 |
Take the radiator out and do your flow test with the radiator upside down. Taping the inlet closed and use a ball in place of the cap, do it until rust flakes stop coming out.
11-05-2022, 08:53 PM | #19 | |
The temp rising after you shut it off is normal, heat soak. Any engine will get warmer when shut off. Take that off your worry list. |
11-06-2022, 10:27 AM | #20 |
Anti-freeze chart, courtesy of Detroit Diesel.
11-06-2022, 10:42 AM | #21 |
New radiators are expensive but really nice to have. Pick the most heavy duty one that fits your car.
11-06-2022, 03:05 PM | #22 | |
Be careful about finding the cheapest radiator you can find. The cheap ones often do not fit well. The Model A vendors (Snyder’s, Bratton’s, etc.) sell radiators that actually fit. Sent from my iPhone using Tapatalk |
11-06-2022, 04:22 PM | #23 |
Good afternoon...When it come to these sorts of parts, there is an old saying 'Cheep people usually pay twice!' Once for the cheep part and then again for the good part after the cheep one fails. Model A's are simple but lots of work...no fun doing the same job for the second time...it can make you say bad words! Ernie in Arizona
11-06-2022, 07:54 PM | #24 |
Thanks for the info. Today i put in a gallon of Prestone. 1 bottle of Rislone Hyper cool super coolant and a little over a gallon of water. Took it for a drive. Shut off the engine. Temperature at the top of the radiator is about the same but now I'm not seeing steam coming out of the overflow tube! Just some coolant. But I think it's still too hot.
I am waiting on a set of feeler gauge from Amazon so I can check the points. When I sold my '69 Mustang years ago I threw in the feeler gauge because I was sure I would never need another! My mechanic neighbor says it's not an original radiator and it has been fixed at least once before. I'm thinking I will probably need a new radiator. Any recommendations? I want to be able to drive the car at least 50 miles to car shows. Do i need to get a pressurized radiator? If i do I assume I would also have to get a leakless water pump? |
11-06-2022, 07:58 PM | #25 |
And yes, I definitely will be buying from one of the Model A suppliers like Synders. How are Brassworks radiators? Pretty pricy.
11-06-2022, 08:18 PM | #26 |
Join Date: Jun 2014 Location: Melbourne, Australia Posts: 6,665 Default Re: 28-29. 30-31 radiator interchange From experience, getting a good one is NOT easy. A few years ago, I bought a Brassworks radiator and recently had to have it repaired. The repair cost me nearly as much as the radiator did, the workmanship was so bad. Even I could see that it was rubbish. From that experience, I have resolved that if I need another radiator, I will have the same workshop recore my old one. My advice would be to find yourself a decent radiator shop and have that done. Other members of this forum might have clues on such a place. |
11-06-2022, 08:20 PM | #27 |
You are using distilled water right?
50/50 on the anti freeze right? Pure anti freeze will make it over heat. Leakless pumps work great. Problem is they are in short supply last time I checked. 200 degrees is too hot. This time of year should be 150-160 tops. I have a temp gauge in mine so I know. |
11-06-2022, 08:33 PM | #28 |
Yes. I checked the mixture with prestone tester. Its good to to 25-. Looks like I must have about 55% water 45% prestone. Ill drain some out and add more prestone till its good down to about 40-. I definately want a temp gauge. Ill need the water outlet with a fitting for that?
11-06-2022, 09:26 PM | #29 | |
https://www.brattons.com/28-29-WATER...uctinfo/11961/ However, this is what I use. It lets you add a thermostat close to the head, rather than in the water pipe. I run a 160 degree thermostat, and it usually never gets higher than 170 degrees, even on a hill. http://www.vintageprecision.com/prod...ing/index.html Sent from my iPhone using Tapatalk |
11-07-2022, 05:10 AM | #30 |
A while back, I had one of these thermostats in the upper radiator hose, but the Vintage Model A Thermostat Housing works much better.
https://www.brattons.com/160-DEGREE-...uctinfo/12020/ Sent from my iPhone using Tapatalk |
11-07-2022, 10:46 AM | #31 |
I like the vintage precision thermostat housing. Looks like a good approach.
