01-12-2018, 11:28 PM | #1 |
‘48 Rear Drums
I’m trying to find a set of rear brake drums without the hubs for a 1948 Super Deluxe. The hubs are inside mount. Mac’s sells new drums for $130. I think this is crazy, I can buy drums for my 1 ton truck for $80. And I haven’t been really impressed with the quality of parts from Mac’s. Does anyone know where I can find drums cheaper than Mac’s? I’ve tried NAPA, Oreillys and Autozone but they don’t show that they have anything for that car.
01-13-2018, 12:49 AM | #2 |
Re: ‘48 Rear Drums
replacing drums is a big deal. you need to cut the swedged studs with a hole saw before you press them out, or bend the hub. there is only two makers of the drums, chinese stuff from macs and others, or.... gol dangit, on the tip of my tongue, the folks that make the new hubs and lincoln backing plates? sombody will help! but you need new studs, modern splined things and true drums after they are mounted, its a big deal MT products, i believe makes the good drums
01-13-2018, 01:03 AM | #3 |
Re: ‘48 Rear Drums
Get drum from MT Auto Products. Replace the swedged studs with modern studs that don't need to be pressed in. The only way to go and I have done it on two cars, 36 and 41.
41 woodie https://41fordwoodie.weebly.com/ |
01-13-2018, 01:04 AM | #4 |
Re: ‘48 Rear Drums
Boling Bros makes the quality MT stuff. http://www.bolingbrothers.com/replacement-parts/
Speedway sells their own version of the drum, Chinese made too. No matter what you get; you will have to deal with the studs and possibly drum lip to backing plates interference requiring a little machine work. |
01-13-2018, 01:16 AM | #5 |
Re: ‘48 Rear Drums
thanks rich for posting the real deal, i couldnt remember!
01-13-2018, 11:18 AM | #6 |
Re: ‘48 Rear Drums
01-13-2018, 11:45 AM | #7 |
Re: ‘48 Rear Drums
I used studs for F1/F-100 hubs. The shoulder was the right diameter to fit the drum and the length was perfect. I opened the hub hole to something almost 5/8". This is with Speedway drums.
01-13-2018, 03:02 PM | #8 |
Re: ‘48 Rear Drums
I've used 2 different vendors (but most likely the same drum manufacture) of the original style drums with bad results. BOTH sets of drums were warped, both places would replace them at my cost for shipping. I turned them to make them better but still where warped. My next purchase will be the Lincolns from MT.
To answer your price question, that is the going rate, unless you get good used. |
01-13-2018, 03:12 PM | #9 |
Re: ‘48 Rear Drums
Early Ford Parts in San Dimas has the drums... they have everything you need! I did the MT bendix upgrade a year ago... I could only afford the separate hub & drums for the rears.. but I didn't have to replace any studs.. I ended up with them because my original hub/drum combined had a stripped stud.. and even though I told the machine shop to be careful, they messed up & warped the hub.. I am extremely happy with the MT bendix style
WALT "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". "Old enough for the experience & too young to know better" |
01-13-2018, 04:02 PM | #10 |
Re: ‘48 Rear Drums
On Boling's web sight they recommend reaming the original holes to .600" and using Dorman 610-234 studs.
01-13-2018, 05:32 PM | #11 |
Re: ‘48 Rear Drums
01-13-2018, 06:24 PM | #12 |
Re: ‘48 Rear Drums
I used the press in studs on my '47, but the ones they sell you are for the repo hubs which are thick. They really stick out of the rear hubs bad (hub inside the drum). I used Dorman 610-191 and had to slightly taper the new drum with a stone on the inside of the rear. If you have a lathe you can turn the end down (I didn't when I put this together in 2008). This is with a .600 hole to start with.
With the 610-234 studs you buy repo: With the 610-191 studs: |
01-14-2018, 01:39 AM | #13 |
Re: ‘48 Rear Drums
Think I saw brake drums at RockAuto.com the other night.
01-14-2018, 04:18 AM | #14 |
Re: ‘48 Rear Drums
^ I'd be surprised if they have, I looked a couple of weeks ago.
In fact I just checked, they have nothing against 1947 or 1948. What they do have is drums listed for the 1948 F1. those are 11", however, not what we are discussing here. Mart. |
01-14-2018, 07:34 AM | #15 | |
Re: ‘48 Rear Drums
With the pressed in studs you used, the new drum just floats ? Like a later style rear drum on a truck? |
01-14-2018, 08:33 AM | #16 |
Re: ‘48 Rear Drums
Hub-centered. The ID of the hole in the drum and the OD of the shoulder on the hub match and center the drum on the hub. The studs just hold the wheel on.
As contrasted to a Model A (lug centered) where the swaged lugs locate the drum on the hub and which require centering/turning after assembly to make sure the drum is centered on the hub. |
01-15-2018, 01:48 AM | #17 |
Re: ‘48 Rear Drums
Yes, they’re hub centric. These are aftermarket drums, if your using stock drums you might need to open up the lug holes a little......I’ll find out when the ‘28 is done .
01-15-2018, 11:46 AM | #18 |
Re: ‘48 Rear Drums
610-109 is what I have used on the front hubs.
01-15-2018, 12:13 PM | #19 | |
Re: ‘48 Rear Drums
Then, use a bit 5/8" or so. Keep the depth so that you're not going to cut into the hub (or drum) itself. If you stop a bit short, a punch and hammer will break off the last bit of the stud flange. Karl |
02-12-2018, 10:59 AM | #20 |
Re: ‘48 Rear Drums
Has anyone used these drums from speedway? I'm curious how they compare to the Boling Bros. drums? What does Bendix style mean? I have 12" juice brakes with inside mounted hubs.
https://www.speedwaymotors.com/12-x-...akes,5847.html |
02-12-2018, 11:19 AM | #21 |
Re: ‘48 Rear Drums
There were two type of brake systems used, the first were Lockheed. These were later replaced by Bendix. They are very different in the way they function. In very basic terms, the Lockheed brake shoes are held in place with a pivot at the bottom, the Bendix "float" at the bottom. Bendix brake are what you would be familiar with on modern drum brake cars. The attached photos ae Lockheed style brakes.
02-12-2018, 11:31 AM | #22 |
Re: ‘48 Rear Drums
From another Ford site:
"LOCKHEED ‘39 THROUGH ’48 FORDS AND MERCS: These brakes were designed and manufactured by Lockheed. Hydraulic pressure expands the wheel cylinder cups, which push the shoes against the drum. The shoes are NOT self-energizing. The Lockheed system is a front/rear shoe design with the bottom pivot for each shoe anchored to the backing plate. This design requires more pedal pressure to stop than self-energizing brakes since they rely solely on hydraulic pressure. The front shoes (primary) do most of the stopping and normally use a longer friction band. The rear shoes (secondary) normally use a shorter friction band." "‘39-’48 LINCOLNS AND ’49-’53 FORD/MERC: These are designed and manufactured by the Bendix Corp. They are self energizing (often referred to as duo servo) brakes. The self energizing is caused by the two shoes being linked to each other at the bottom, but are NOT attached to the backing plate (like the Lockheed design is). The top of the primary shoe is moved outward by hydraulic pressure from the wheel cylinder to contact the drum. The rotation of the drum “wedges” the floating primary shoe to move it downward. Since the bottom of the two shoes are not anchored to the backing plate, this rotation movement is transmitted through the rear most shoe where it forces the shoe against the drum. This increases braking substantially and decreases brake pedal effort. This results in considerably more braking force than the sheer hydraulic pressure design used in the earlier Lockheed brakes. The primary of a Bendix system is still the front shoe in all wheels... just like the Lockheed brakes are. However since the Bendix is self-energizing, the rear (secondary) shoe applies much more stopping than the front (primary) shoe does. The secondary shoe now has the longer friction band and the primary now has the shorter friction band." |
02-12-2018, 01:00 PM | #23 | ||
Re: ‘48 Rear Drums
BENDIX--style is what the more modern type of drum/shoe brakes (like the MTs) are called. The shoes are not rigidly mounted to the backing plates....they're allowed to float. The stock old Ford brakes have the shoes mounted to a pivot at the bottom of the backing plate. These are called LOCKHEED-style brakes, and are NOT self-energizing. DD |
02-12-2018, 03:15 PM | #24 |
Re: ‘48 Rear Drums
Thanks for the information. Attached are pictures of my drum/hub and rear brake assembly. It is an inside the drum mounted hub. Most places do show that it should be an outside mounted hub those years but I have seen a few places that do show an inside mounted hub available in '48. It does have the Columbia rear if that makes any difference. It's clear to me now that I do not have Bendix brakes so I am assuming the Speedway drums will not work. Every measurement was the same with the Speedway drums except the overall diameter. Mine is approx. 13.37" and the Speedway drum is 13.63".
So, there are no dimensions on the Boling Bros. website. Is there drum the same size as the one from Speedway or is it the correct size for my setup? |
02-12-2018, 03:20 PM | #25 | |
Re: ‘48 Rear Drums
02-12-2018, 03:27 PM | #26 |
Re: ‘48 Rear Drums
02-12-2018, 03:37 PM | #27 | |
Re: ‘48 Rear Drums
Otterby.....It's your lucky day!! Those drums/hubs that you pictured are the early ('40-'41) style. They work every bit as well as the '46-'48, and the IMPORTANT dimensions (like lining-up with brake shoes and fitting axle properly) are identical. The brake drums we're talking about are ALL considered to be 12" drums. Brake drums are measured across the drum from one shoe surface to the other shoe surface.....INSIDE the drum! Re-measure yours, and you will probably end-up with 12.0??", or even larger by a few thousandths. The brake drum does not know the difference between Lockheed style and Bendix style brakes. The drum just provides an internal, flat surface for the shoes to rub against. The "LUCKY" part about your day is that you need those early "INSIDE THE DRUM" hubs to fit the MT replacement drums. I've heard that the Speedway drums are produced "offshore". I also have first-hand experience with the MT American-made parts. I'd stick with the MT stuff. Boling Bros. is the way to go. Their drum IS the right size. It is 12.000" measured inside, across the center. Does this further help ya understand about these old brakes? More questions.......ask away! DD |
02-12-2018, 03:43 PM | #28 | |
Re: ‘48 Rear Drums
02-12-2018, 04:13 PM | #29 |
Re: ‘48 Rear Drums
By the way, the brake shoes on this left, rear of the car are mounted on the backing plate BACKWARDS. With LOCKHEED brakes (which we now know they are), the shoe with the long lining goes toward the front of the vehicle. The large part of the wheel cylinder also goes toward the front, which this one does, correctly. DD
02-12-2018, 04:21 PM | #30 |
Re: ‘48 Rear Drums
I think that's the gas tank to the right , making the left the front . I think ?
02-12-2018, 04:41 PM | #31 |
Re: ‘48 Rear Drums
Correct.....which makes this the left (driver side), rear brake (obvious) on the car. The REAR shoe (long lining) should be mounted toward the front, which it ain't in this pic. DD
02-12-2018, 05:27 PM | #32 | |
Re: ‘48 Rear Drums
I'll have to double check tonight but I'm positive my service manual showed the short lined shoe towards the front? I didn't question it because that's the way the old ones were installed. I really appreciate you pointing that out if you think they're wrong though! |
02-12-2018, 05:33 PM | #33 |
Re: ‘48 Rear Drums
I always just remember "Big Big" for the early ford brakes big lining and big end of the cylinder go towards the front. This goes for any wheel, front or rear.
Where the confusion sometimes comes from is that later self energising (Bendix style) brakes normally have the shorter shoe to the front. But for early Fords, Big Big is the rule. Mart. |
02-12-2018, 05:57 PM | #34 |
Re: ‘48 Rear Drums
Here is the diagram I used from the manual. I obviously need to pay closer attention. I assumed this was for the left side by the way the squiggly underline is under "ASS'Y LEFT". However, now that I look at the parking brake hardware and how the brake cable enters the backing plate it's clear the diagram is of the right side. Thanks for catching that!
02-12-2018, 06:09 PM | #35 |
Re: ‘48 Rear Drums
I can see where the confusion can stem from. If you're going to show the front and rear brakes on the right side, at least put the rear to the left of the front. (Front of car is on the right of the pic).
Lot of good info in the pic, though. Mart. |
02-13-2018, 07:32 AM | #36 |
Re: ‘48 Rear Drums
The ford drums I don't think they are marked with 12.060 max.
I think to cut larger started after 1948 There is all most 3/4" of meat on the drums. Throwing good drums away when they could be turned to 12 .150, I would really like to see a egg shaped 1948 drum. If you have a chance to die take it. |
02-13-2018, 08:46 AM | #37 |
Re: ‘48 Rear Drums
I don't have an earlier Ford Service Manual in front of me, but the 49 - 52 manual states to not bore the drums past the recommended limits. The limits are listed under brake specifications and appear fairly standard, example for F1 is 11.060.
02-13-2018, 08:54 AM | #38 |
Re: ‘48 Rear Drums
FYI: Here's what the MT Products Boling Bros. 12 in. drums look like. They are worth the money. Plus, you no longer have to use a wheel puller to remove the drums.
02-13-2018, 10:16 AM | #39 |
‘48 Rear Drums
It kills me when I see prices at of around $100.00 for a brake drum.
I have been in the business for 50 years and the prices we pay for drums is a rip off just because we are driving classic cars, the same drums for normal cars are a fraction of the cost Sent from my iPhone using Tapatalk |
02-13-2018, 11:10 AM | #40 | |
Re: ‘48 Rear Drums
I don't get it either. With shipping, just two drums will be close to $300. It's crazy how much more some things cost. I do need rear drums though and am going to get the Boling Bros. drums. It's pretty clear that they're a quality product and I agree that the brakes are nothing to get cheap on. I was able to turn the front drums and they now measure out at around 12.020 so I'm comfortable with that. |
02-13-2018, 11:29 AM | #41 |
Re: ‘48 Rear Drums
I'm glad to pay the ticket for MT USA made products. Never had a complaint since I started selling their products.
02-13-2018, 11:41 AM | #42 |
Re: ‘48 Rear Drums
It's called "Economy of scale". Think of how many cars out there can use the drums in the ad versus the number of old Fords needing them. If I could make and sell my 6 volt tach drivers in quantities of the thousands, I could sell them at 1/3 of what I need to get now.
02-13-2018, 12:05 PM | #43 |
Re: ‘48 Rear Drums
I can see both sides of this price/quality issue on brake drums. Any custom type of production on a part with a limited market is going to be expensive. That is why I run F1 brakes (and cheat a little, LOL). I can run later F100/F150 drums that are American made high quality and very reasonably priced. Also easy to find replacements! But, that is just me, if you want suppliers to provide quality parts you are going to have to pay the required pricing.
02-13-2018, 12:54 PM | #44 | |
Re: ‘48 Rear Drums
What year F1 drums are you running and do you know the hub diameter Sent from my iPhone using Tapatalk |
02-13-2018, 01:08 PM | #45 |
Re: ‘48 Rear Drums
These are F100/F150 drums that will work with the F1 hub (F1 only, not the F100 hubs). I say "cheat" a little because the drum braking surface is wider than the brake shoes that are used. The F1 style drums step down, where these drums are squared off in side profile. They are 5 X 5 1/2 drums.
