Old 05-24-2021, 10:52 AM   #1
Standing Elk
Default Intake leak
What is the best way to check for an intake manifold leak? Thanks
Standing Elk is offline   Reply With Quote
Old 05-24-2021, 11:08 AM   #2
jayvee34
jayvee34's Avatar
Default Re: Intake leak
With engine running at idle spray carburetor cleaner along the intake. If engine speeds up
slightly you have a leak. If engine won't idle down you probably have a vacuum leak
somewhere.
Hope this helps.
John
P.S. keep spray away from hot exhaust manifold. spray is flammable.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 05-24-2021, 01:29 PM   #3
Benson
Best thing I have found is to use a small rubber hose like windshield wiper fluid hose and listen for leaks around manifold while engine is running.
At 74 I can still hear well enough to tell if there is a leak.
Problem with un-lit torch or Carb cleaner is that the fumes find there way to carb inlet and change the speed giving false indication.
That is my experience anyway ... For what is worth.
Old 05-24-2021, 03:03 PM   #4
Patrick L.
Patrick L.'s Avatar
I like propane or ether [ start fluid].
Old 05-25-2021, 08:56 AM   #5
old31
I like propane, it does not leave a mess. When it finds a leak the RPMs will increase.
old31 is offline   Reply With Quote
