02-01-2012, 11:15 PM | #1 |
my alternator that look like a generator
Thought I would post this as well
02-01-2012, 11:53 PM | #2 |
Re: my alternator that look like a generator
02-02-2012, 12:07 AM | #3 |
What is the function of the cut out or is it a dummy??
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
02-02-2012, 07:52 AM | #4 |
Yes the cut off is a dummy I am going to make a better one just havent found an original cut off yet. As far as the alternator it is a mini race alternator and I built the housing and used an original generator back but drilled the holes larger for air flow.
02-02-2012, 07:54 AM | #5 |
I might mention if you will take a close look at the front you can see just a little bit of the alternator I was going to cover it but was afraid it wouldnt cool enough.
02-02-2012, 08:13 AM | #6 |
AL in NY |
02-02-2012, 08:42 AM | #7 |
Your conversion might be worth a "how to" write up for one of the Model A magazines.
02-02-2012, 08:43 AM | #8 |
I could not agree more!!
02-02-2012, 08:55 AM | #9 |
Hi Al, the alternator can be purchased off of eBay they make them 40, 50, 80 ,100, amp all the same size just type in Mini alternator mine came from DB electrical , the generator cover I made in my fabrication shop you have do some cutting on the alternator Which will void the warranty and some welding on the back bracket, also had to build a new bracket to hold the housing and alternator. the only part of the generator is the back. by the way our trucks are the same color
02-02-2012, 09:01 AM | #10 |
So cool
02-02-2012, 09:05 AM | #11 |
My concern is the fan on the alternator pulls air through the alternator and blows it out of the front via the edges of the fan / impeller. It looks like your case covers most of the edge of the fan?
02-02-2012, 09:23 AM | #12 |
02-02-2012, 09:31 AM | #13 |
John/CT, not the same as oljoe001's homemade genernator. At $86 bucks on ebay for the mini alternator, it's a dame site cheaper to make one then purchase the commericially made genernator at $800+.
AL in NY |
02-02-2012, 11:32 AM | #14 |
I wonder how much work it would take to put one in a powerhouse case. I might look into this further later this year. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
02-02-2012, 11:42 AM | #15 |
02-02-2012, 12:24 PM | #16 |
Jeff's right. I love my alternator except when I have to raise the hood. It looks out of time and place.
02-02-2012, 12:32 PM | #17 |
I don't know, I've always liked the look of an alternator. When I see a generator the first thing that comes to mind is "limp"
02-02-2012, 12:40 PM | #18 |
When I go to the lcl. car shows I only open the right side of the hood any way, so my alt. is out of site. The other reason I like to leave the left side closed is one show I went to last sunner some one pulled my oil dip stick out and when they put it back in they did not squeze the handle in and when I got home I had oil on the fire wall and around the dip stick hole.
To me the alt. is far better then the org. gen. jmo |
02-02-2012, 12:45 PM | #19 |
Hi this unit has an internal fan and no obstructions from the front, I drilled out the back of the original generator cap for ample airflow.
Joe |
02-02-2012, 12:46 PM | #20 |
Hi It wont fit I made the case it is in.
Thanks Joe |
