Old 10-06-2013, 05:04 PM   #1
roll of the dices
roll of the dices's Avatar
Default Tail light mounting location for 1936 Truck
I bought a tail light bracket to be used with rear bumper for 1936 Ford Truck; however, I am lost as to how or where exactly it mounts.
It appears to mount to the frame but I see no existing holes...almost feels like I am missing a bracket of some type.
Can someone help me with a picture of proper way to mount it? Thank you in advance
It looks like this http://macsautoparts.com/early-ford-...R3CHL1142107E/
...let your brain do the thinking and your fingers do the walking...
roll of the dices is offline   Reply With Quote
Old 10-06-2013, 05:57 PM   #2
jerry grayson
Default Re: Tail light mounting location for 1936 Truck
This is not for a pickup, it is for a big truck.
jerry grayson is offline   Reply With Quote
Old 10-06-2013, 06:34 PM   #3
hotcoupe
hotcoupe's Avatar
these are re-pops on my `37, but i think they are correct for your `36.
hotcoupe is offline   Reply With Quote
Old 10-06-2013, 07:34 PM   #4
banjoQ
banjoQ's Avatar
I have four round lights mounted underneath the tailgate on mine. This might have been a commercial application. Only one of these works currently, so I have mounted a 37' light on the left as did Hot Coupe. There are a couple of bolts on the back of the box that fit the bracket. Wish all the problems were that easy to remedy.
banjoQ is offline   Reply With Quote
Old 10-06-2013, 07:56 PM   #5
Lawson Cox
Lawson Cox's Avatar
Hopefully previous postings have shown you how the tail lights mount on a 36 with a rear bumper. If not, email me direct at [email protected]
and I can furnish you with a couple of pictures. Just learning a new computer and haven't figured it all out yet.
Old 10-07-2013, 07:45 PM   #6
roll of the dices
What's correct for the half ton? I only see the flat bracket that mounts behind the stake pocket but claims 1937 and up
Old 10-07-2013, 10:10 PM   #7
Lawson Cox
Lawson Cox's Avatar
Enlarge photo posted by Hot Coupe and study it carefully. That bracket is what you are looking for. Correct bracket has an offset to it, which moves it out from the bed. Flat bracket is for pickup without a bumper. You probably will have to drill new holes for the correct bracket. You probably will have to grind off a rivet to drill one of the holes, but I can't remember exactly, I reiterate, send me an email at [email protected] and I will send you a photo of how it mounts on a Dearborn class 36 truck with a rear bumper.
As Jerry Grayson says, the bracket shown in Mac's book is for a large truck.
Old 10-08-2013, 07:49 PM   #8
roll of the dices
I appreciate the pictures of the info. Thank you Lawson that email helped! now see that I have the wrong set of brackets.
My problem seems that I can't find the right brackets. I checked with Mac and early Ford parts and they don't carry these....any one with a lead on where I could get a set or should I just try my luck in the classified section?
Thank you everyone!
Old 10-08-2013, 10:32 PM   #9
hotcoupe
hotcoupe's Avatar
www.mackhilsmetalfabrication.com/ reproduces the tail light bracket that i used on my `37. however they only make the left side [driver], so you have to cut one apart and weld it back together - because of the offset.
tom
Old 10-08-2013, 11:19 PM   #10
Brendan
Brendan's Avatar
you got the bracket mounted on the wrong side
it should be on the other side of the pocket
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 10-09-2013, 10:43 AM   #11
Karl Wescott
Karl Wescott's Avatar
tom
Rather than the cut and weld route, consider the heat and bend path. Those brackets are mild steel and should stand up to a little shade tree blacksmith work well.
Karl Wescott is offline   Reply With Quote
