Old 03-12-2014, 06:27 PM   #1
Robie
Exclamation Rusty spark plugs
What causes internal rusty 3X spark plugs when in good running engine ?
Only #2 plug. Cracked head or bad gasket ?
Robie is offline   Reply With Quote
Old 03-12-2014, 07:09 PM   #2
Ray64
Ray64's Avatar
Default Re: Rusty spark plugs
Im thinking some water penetration If the plug is really clean
Ray64 is offline   Reply With Quote
Old 03-12-2014, 07:36 PM   #3
SeaSlugs
SeaSlugs's Avatar
when was the engine last ran? air and moisture can still collect inside the cylinders...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 03-12-2014, 07:52 PM   #4
jw hash
jw hash's Avatar
sound like you have water in that cylinder it does not take much. run it till it is worm let it set over night and pull that plug if there is ANY moisture on the plug at all, pull the head and fix it. it is better to be safe then sorry.
jw hash is offline   Reply With Quote
Old 03-12-2014, 08:27 PM   #5
Joe K
Joe K's Avatar
Valve open on No. 2 cylinder when the engine stopped?
I had a mouse set up winter quarters in Cylinder No. 4 of my Gordon Smith Air Compressor (see avatar) Made an awful mess of things. To the tune of $400 to straighten it all out.
How did he crawl up that tailpipe (cut off about 4' long) through that muffler?
Joe K
Shudda kept the horse.
