Old 07-14-2014, 06:53 AM   #1
Bud
Bud's Avatar
Default Changing Stripe Color
Is it feasible to change, say a Straw stripe to a Hessian Blue stripe that has been painted on the body and gas tank? Or is this a job that would require sanding off the old stripe completely before adding the new color? Would one simply paint over the old stripe with the new color?
Thanks in advance for your reply.
Bud is offline   Reply With Quote
Old 07-14-2014, 08:10 AM   #2
C26Pinelake
Default Re: Changing Stripe Color
Freehand is not an easy job for us amateurs ! I started and quickly realized it is a form of art. I hired a professional and he did a great job. I got 2 done at one time and he charged $175 for the Cabriolet and $125 for the pickup.
Wayne
C26Pinelake is offline   Reply With Quote
Old 07-14-2014, 10:08 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
The professional would carefully remove the old stripe with a rag and compound, then paint on the new stripe.
Old 07-14-2014, 12:01 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Vermin's stripes are TOO wide & look FUNKY, I'll have my striper run a body color stripe in the middle of it, to make it look like 2 SKINNY stripes.
On the Straw colored 16" wheels, he'll run a body colored stripe on the outer rim, to sorta' "TIE" them in with the body color. I know it ain't original, BUT, I think it'll look GOOD!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-14-2014, 07:43 PM   #5
Bruce,Upstate NY
I have removed old stripe with really fine wet sandpaper paper on a block, maybe three to four thousand grit, then compound, then restripe. I have seen stripe only several years old that I was able to remove with a razor blade, then compound. I suspect it was One Shot lettering enamel.
Bruce,Upstate NY is offline   Reply With Quote
Old 07-14-2014, 09:18 PM   #6
Logan
Logan's Avatar
Old stripe will come off real easy with 2000 grit sand paper if you wet sand it off. Then buff and polish where the 2000 grit scratch was. Then the striper can put on a new stripe. But if you don't know what you're doing you can easily sand the paint off underneath the stripe or in the surrounding area. You only want to sand the stripe. Not the area around the stripe as well.
Cowtown A's
Logan is offline   Reply With Quote
Old 07-14-2014, 11:36 PM   #7
tbirdtbird
One Shot is commonly used by stripers and will come off with lacquer thinner. It is just enamel
'31 180A
tbirdtbird is offline   Reply With Quote
