Old 08-05-2012, 09:35 PM   #1
Cape Codder
Cape Codder's Avatar
Default Painting of Parts
How do most paint small parts when rebuilding starters, generators and backer plates? Do you spray with spray cans after primer or with a gun? Any difference in the end results between the spray cans and gun?
Thanks for your time.
Joe Grobleski
Cape Codder is offline   Reply With Quote
Old 08-05-2012, 09:44 PM   #2
Fred K-OR
Fred K-OR's Avatar
Default Re: Painting of Parts
I use spray cans for small parts. But I have two drivers that do not require them to be perfect.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 08-05-2012, 10:14 PM   #3
'29wagon
small parts only at this point. i use the rattle can, as it allows me to not need to clean up equipment. just spray and store for the one day i actually reassemble it. someday.
'29wagon is offline   Reply With Quote
Old 08-05-2012, 10:28 PM   #4
PetesPonies
PetesPonies's Avatar
cape . longevity is going to be better with a spray gun as the paint can have hardener added. Using urethane paint with hardener is going to leave a finish that will last forever, if prepped right. However, proper prep and a spray can will work for most people. It's up to you. It is much quicker using a spray can, but with proper prep and etch primer, you can do a reasonable job with a can.
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
