09-21-2020, 04:19 PM | #1 |
Rear Spring Installation
I recently did some work on my drive train and did so by removing the rear end, spring and all. I removed the spring to make some repairs, and have mated the spring to the rear end. I am now in the process of re-installing, but am having some difficulty. The spring fits into the channel and I am ably to tighten the nuts to the original u-bolts, but I am unable to do so enough to insert the cotter pins. I have checked to ensure that the spring bolt is in the frame hole, but still no joy. Any suggestions? As a side note, others have recommended that I should have left the spring in and just removed the rear end at the shackles, but I am beyond that. One option is to remove the spring from the rear end, install just the spring, and then install the rear end with the spring already installed.
Joe/Ct "The older I get, the better I was" |
09-21-2020, 04:20 PM | #2 | |
Re: Rear Spring Installation
09-21-2020, 04:55 PM | #3 |
MMMM Perhaps lower the car with wheels installed. The weight with the car on the ground may the difference.
09-21-2020, 05:28 PM | #4 |
Did you change or remove the top spring leaf?
09-21-2020, 05:51 PM | #5 |
Are you using the spring clamps for the 7 leaf spring?
Different leaf counts require different clamps.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
09-21-2020, 05:59 PM | #6 |
Tom Endy |
09-21-2020, 07:26 PM | #7 |
Have you added an extra leaf ?
Is the center bolt tight ? Is the square of the center bolt head protruding thru the crossmember hole ? |
09-21-2020, 08:18 PM | #8 | |
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 09-21-2020 at 08:18 PM. Reason: Addition. |
09-21-2020, 08:21 PM | #9 |
No I did not. The only work that I did was in the torque tube. The springs, u-bolts and nuts were as original.
09-21-2020, 08:22 PM | #10 |
I changes nothing on the spring.
09-21-2020, 08:23 PM | #11 | |
09-21-2020, 08:24 PM | #12 |
I am out by 1/4" all 4 bolts....
09-21-2020, 08:26 PM | #13 |
I changed nothing on the spring and, yes, the center bolt is tight...
09-21-2020, 08:30 PM | #14 |
Maybe you have the spring clips upside down?
09-21-2020, 08:47 PM | #15 |
Just about the thickness of the square head of the bolt not aligned with the square hole in the cross member. It's happened to me.
09-21-2020, 10:08 PM | #16 |
I don't think so...do you have a pic how they are to be installed?
09-22-2020, 11:16 AM | #17 |
Are the tabs on the u-bolts in the holes on the cross member?
09-23-2020, 09:35 PM | #18 |
Yup. I am using the spring clips that were originally on the car. All I did was remove the drive train, including the spring. I then removed the spring from the axles to make it easy to repair the drive shaft. I reinstalled the spring, inserted in the vehicle and used the original spring clips. Unfortunately, I was unable to tighten the nuts enough to insert the cotter pins.
Note that Andrews recommends removing the the rear end with the spring attached while some of the guys at the shop suggest leaving the spring on the vehicle and removing the shackles.
09-24-2020, 08:24 AM | #19 |
Just a thought as the spring flexes it wears a groove into the leaf below it,if you have no weight on the spring while trying to tighten the spring clips possibly the leaves are resting on the unworn or high spots,lower the back of the car to the ground and or have a couple of people sit in the back and then see if you can tighten those nuts the xtra 1/4 inch.
09-24-2020, 11:50 AM | #20 |
It usually is easier to remove the rear axle with the spring installed but it also depends on what else is disassembled during the whole repair process. Removing the spring from the rear axle is not normally a big deal but it would be easy to reinstall it 180 degrees from where it was originally and that might have changed the fit just enough so that things aren't seating like they were before. A person needs to confirm that the spring is seated all the way and that those U-bolts are also seated as they should be.
If the spring was not disassembled then it should not affect fit other than the way it seats into the cross member. |
