Old 08-06-2013, 05:22 PM   #1
Super88
Super88's Avatar
Question Rivet Question
While replacing the rear header on my 1930 Tudor, the right side corner bracket that attaches to the rear roof panel came off. It was held to the roof panel by one rivet that appears to have the "waffle" pattern on the end.
Considering the small amount of room, how was this rivet set? Since it will never be seen again once the car is completed, would it just be easier to replace the rivet with a nut and bolt?
Super88 is offline   Reply With Quote
Old 08-06-2013, 05:33 PM   #2
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default Re: Rivet Question
You can definitely do that, make sure you use some good lock tight and your set to go. Back then there was a certain pattern to what was riveted in what order and they had bucking bars that were also designed to get into places...the engineers knew exactly what to do.
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 08-06-2013, 07:24 PM   #3
1931 flamingo
1931 flamingo's Avatar
As Mark says.
Even if going for fine point, only you will know once the upholstery goes in...............JMO
Paul in CT
Old 08-06-2013, 07:53 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Does "PARANOIA" ever set in when HIDING non-original fasteners, methods, etc? Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-06-2013, 10:00 PM   #5
mass A man
mass A man's Avatar
Definately get out your nut and bolt cans and bolt 'er up.
mass A man is offline   Reply With Quote
Old 08-07-2013, 10:20 AM   #6
Super88
Super88's Avatar
Thanks guys. I will probably go the bolt and nut route. I would be somewhat concerned about causing damage trying to get a rivet set in such tight quarters without proper riveting tools. I try hard not to create any "backward" steps as I progress, since they seem to pop up on their own
Old 08-07-2013, 12:34 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Could a pop rivet work in that spot?
That would be a cleaner and closer to original fix than a nut and bolt.
