Old 05-29-2014, 07:25 PM   #1
farmerdick
farmerdick's Avatar
Default 39` syncro trans in 30` roadster
Hey Guys, I`am looking to put a 39` syncro trans in my 30` roadster. My question is: How do I tell the difference from the standard and deluxe trans?
I was told that the deluxe is better. I also need to find the company that offered the adapter kit to install this trans in the model A. The roadster is all stock. Is there any thing to think about as far as the drive shaft is concerned or will the adapter kit deal with this? Are the shifting forks different from standard and deluxe? Not asking for much am I? Any help will be much appreciated. Thanks
Farmer Dick
farmerdick is offline   Reply With Quote
Old 05-29-2014, 07:54 PM   #2
DICK SPADARO
Default Re: 39` syncro trans in 30` roadster
I dont think that there is any gain to this exercise, what is your intention?
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 05-29-2014, 07:56 PM   #3
PeteVS
PeteVS's Avatar
Model A transmission is a totally different animal from the '32 up to '48 transmissions. Different internally and externally. You might be able to fit a Model B transmission to an A engine and use the later (including synchro 2nd and high) gears in that transmission. What appears to me to be a better option is a Mitchell transmission which would give you synchro in a Model A case. Here's a link...
http://www.fordbarn.com/forum/showthread.php?t=21064
(I have no first hand experience here, so there should be some corrections.)
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 05-29-2014, 08:01 PM   #4
Mac VP
Mac VP's Avatar
Spend a few minutes reading up on the Ford early 3 speed trannies on our website. It should help explain the differences. Not all 39 transmissions are the same . Not all transmissions advertised as "39 trans" are anything close to what you hope a 39 trans should be. Here is that link: http://www.vanpeltsales.com/FH_web/f...sID_3speed.htm
Klings has the best adapter kit. I think it's also available thru Snyder Model A Parts.
We build these transmissions. If you don't have a good core for a rebuild, we can build one for you. There may also be other competent builders near you. Ask around for recommendations.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 05-30-2014, 03:02 AM   #5
farmerdick
farmerdick's Avatar
Thanks guys for all the info. This gives me a good starting point as to what I need to do to accomplish what I want to do. My main reason is that I haven`t mastered this double clutching business. I know about the Mitchell trans but is a bit pricy for me.
Richard
Old 05-30-2014, 05:25 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
There is a kit being offered to put a T5 transmission in a Model A. I believe he is a member here. If I can remember his name, will add it later.
John
Old 05-30-2014, 06:40 AM   #7
richard crow
go for the t5 it also has od. if you must up date the car
richard crow is offline   Reply With Quote
Old 05-30-2014, 08:01 AM   #8
texas webb
There's also the 82-87 f-150 trans 3sp w/od.
texas webb is offline   Reply With Quote
Old 05-30-2014, 08:17 AM   #9
Brendan
Brendan's Avatar
Richard
I have a 29 roadster, and drive it all the time. I don't double clutch all the time mainly when I shift from second to first, when you up shift do it slowly shit into neutral and count to three. find a big open parking lot and master your shifting. I did that , and I can shift with out a clutch. with some time you will be a master
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 05-30-2014, 01:11 PM   #10
1931 flamingo
1931 flamingo's Avatar
On the Model A trans, make sure you've got the correct gear oil in it. Double clutching is easy but may take some practice.
Bert's in Denver handles the Cling (no longer in business) conversion kit.
Paul in CT
Old 05-30-2014, 01:57 PM   #11
oldsman41
the upgrade would be the 3 spd od or the s10 5 spd od both not that hard and no double clutching, plus the od is real easy on the motor. if you still want to go the 39 trans you can put a Volvo od unit in the torque tube that's a real nice setup.
oldsman41 is offline   Reply With Quote
Old 05-31-2014, 01:03 PM   #12
1930ABONE
1930ABONE's Avatar
I did this conv a couple years ago...it's all bolt in and a great setup.
https://www.clingsaftermarket.com/index.asp
1930ABONE is offline   Reply With Quote
Old 05-31-2014, 04:12 PM   #13
scooder
Just for clarity, do you actually need to do that into neutral!!! Even done slowly, that'll take some body moves, let alone getting your pants down in time!
Martin
scooder is offline   Reply With Quote
Old 05-31-2014, 11:17 PM   #14
CrazyBackyardBuilder
CrazyBackyardBuilder's Avatar
The Cling's set up is the way to go.
CrazyBackyardBuilder is offline   Reply With Quote
