03-28-2024, 07:05 AM | #21 |
Re: Peep mirrors
Convex Mirrors as said in previous post work wonders!!! I added them to my existing mirrors and made a Huge difference!
03-28-2024, 12:01 PM | #22 | |
Re: Peep mirrors
https://www.amazon.com/Mirror-Wrangl...39&sr=8-1&th=1
03-28-2024, 12:50 PM | #23 |
Re: Peep mirrors
Thanks for the link, Katy. The listing says 'No Drilling'. Does that apply to Model A attachment also?
03-28-2024, 01:18 PM | #24 |
Re: Peep mirrors
I had mirrors on both chromned covered spares. Then convex stick ons one each tire. Worked pretty well. I had a non standard center m1rrror with a clock. It was wider the little oval Henry offered.
03-28-2024, 02:50 PM | #25 |
Re: Peep mirrors
Years ago when I put mine on I ended up parking my A on the driveway, and then parking two of my daily drivers just behind, and along side on each side where I wanted to see. Once you drive with them a while you make minor adjustments, and get them zeroed in. You get used to them. The vibrations calm down with load on the drive line.
03-29-2024, 04:09 PM | #26 |
Re: Peep mirrors
03-29-2024, 08:13 PM | #27 |
Re: Peep mirrors
I like the hinge pin ones. Those ones with thy allen screws always chew up the paint. I have them on my streetrod, and dislike the marks they put on the inside of the door.
03-30-2024, 10:20 AM | #28 |
Re: Peep mirrors
Ditto, that's what's on my CCPU, I replaced the vendor's mirrors w/ones w/a longer stem to allow more adjustment.
04-03-2024, 06:50 PM | #29 |
Re: Peep mirrors
I have a Slant Town Sedan, I wanted a mirror on the right side of the car. I bought a Peep Mirror and have to mount it on top of the door. Couldn't get it close enough to see the side of the car. Took the mirror apart and cold bended the arm that the mirror attaches to. Now I can see the right side of the car, have plenty of adjustment.
04-03-2024, 11:21 PM | #30 | |
Re: Peep mirrors
~Ernie |
04-04-2024, 06:48 AM | #31 |
Re: Peep mirrors
Thanks Ernie.
04-08-2024, 07:45 PM | #32 |
Re: Peep mirrors
Mine has clamp-on ones on the wind wings. You couldn't see anything. I put those round convex mirrors on them and now it's fine. They come in different sizes and most have double sided tape to mount them. $2-4 on FleaBay $6-10 at the parts store.
04-08-2024, 09:01 PM | #33 |
Re: Peep mirrors
I tried the same mirrors you have and could not get them to work. I gave them away and went with the hinge pin mirrors and they work great and no vibration
04-10-2024, 01:56 PM | #34 |
Re: Peep mirrors
To all the folk who mentioned stick-on convex mirrors - do you have a maker of those? I'm looking around for a 4-inch convex to just stick onto the 4-inch Synder's door-attached mirror.....
Thanks! |
04-12-2024, 10:03 PM | #35 |
Re: Peep mirrors
Well...I reversed the clamp and that helps get the mirror where I want, but it does make it only set on a small area of the arm on the door. So I decided to make my own arms. I have access to a CNC plasma cutter, drew them up, and put the passenger one on. I can bend it to where I want. Hardest part was bending the u bolt. Need to make a jig or something. Haven't tested wind resistance or vibration yet as the weather has not cooperated.
04-13-2024, 10:06 PM | #36 |
Re: Peep mirrors
I've found that the mounting stud on the back of some mirrors (sold by some of the vendors) is too short, restricting the adjustment of the mirror. Remedy was to buy different mirrors w/a longer mounting stud.
04-15-2024, 01:21 PM | #37 |
Re: Peep mirrors
I solved the "short mounting stud" delima by adding a 1" barrel nut from the hardware store into the mix.
