Old 06-18-2011, 11:35 AM   #21
Joe/Ct
Joe/Ct's Avatar
Default Re: Model A Quail
Originally Posted by 30Tudor View Post
Not sure I completely understand your problem - a picture would help. Try putting a thin stainless washer/spacer at the radiator end of the hood shaft/rod (on the rod) where the rod enters the front hold-down bracket. The washer sits between the hold-down bracket and the first hood panel hinge and will move the hood panels back. I had to do this modification last weekend because the edge of the hood panels were hitting the tail of my quail. One member in our club uses a slice cut out of stainless steel tubing.
Thanks for the input regarding the washer. However, my problem is that my hinge rod is not long enough to fit into both the front and rear hold-down brackets when I move the radiator forward. I do like the idea of possibly using some tubing to extend it.
Joe/Ct
"The older I get, the better I was"
Joe/Ct is offline   Reply With Quote
Old 06-19-2011, 10:04 AM   #22
Ray in La Mesa
If your hinge rod is hollow, you can find a solid rod to fit tightly inside the original hood rod and cut it to the right length.
Ray in La Mesa is offline   Reply With Quote
Old 06-19-2011, 01:09 PM   #23
modelAtony
modelAtony's Avatar
ebay was orig 2600.00 range few months ago
modelAtony is offline   Reply With Quote
Old 11-11-2011, 10:06 PM   #24
f1builder
i think my quail is a 29 also. it is 4 3/4" long and 3" wide and almost 3" tall. nice condition for its age. no radiator cap, just the quail. are these really worth what was posted?
f1builder is offline   Reply With Quote
Old 09-18-2021, 06:07 PM   #25
[email protected]
Do you have a photo for an example please? I’m having the same problem, the hood is hitting the quail tail when opened. Thank you
chadvband@gmail.com is offline   Reply With Quote
