Old 06-12-2018, 05:34 PM   #1
upd8922
Angry 1928 Model A AR Brakes
I own a 1928 Model A Ford Leatherback. I'm kinda restoring it a little bit at a time. My current project is the brake system. I had the liners replaced, the Front brake pins replaced. Rear brake liners replaced along with some pins and clevis replaced. During this venture we noticed that I have a AR model due to the brake arm levers and the plate on the left side where the original e-brake arm was. Anyways, me and my mechanic just can't get the car to stop properly. I know that they are mechanical brakes and really don't stop well, but it should stop than they are. I recently noticed some play where the equalizer shift goes into brake levers. So I had the levers fixed by having them machined and drilled for a tighter fit with the equalizer shaft. Any suggestions that could help me I would accept.
upd8922 is offline   Reply With Quote
Old 06-12-2018, 07:13 PM   #2
Steve Wastler
Steve Wastler's Avatar
Default Re: 1928 Model A AR Brakes
Correct mechanical brakes will stop extremely well when adjusted correctly, keep trying
Steve Wastler is offline   Reply With Quote
Old 06-12-2018, 10:25 PM   #3
upd8922
Do you think using the board between the brake pedal and seat could work?
Old 06-12-2018, 10:32 PM   #4
Roadster62
Roadster62's Avatar
There is an "AR" in the shop I work part time, that equalizer just looks scary, are they really designed to be that sloppy? Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 06-13-2018, 02:55 AM   #5
upd8922
I appreciate the response. My shaft was sloppy. I had brought it to a machine shop, where metal was added and drill for the persistent fit to the shaft. It's not as sloppy.
Old 06-13-2018, 04:05 AM   #6
juke joint johnny
juke joint johnny's Avatar
Are you using the soft woven linings ?
The bonded hard modern linings don't work very well on rod brakes,
Radius the brake shoes to the inside of the drums so the whole shoe makes contact with the drum
Where are you located?
juke joint johnny is offline   Reply With Quote
Old 06-13-2018, 08:13 AM   #7
Jim/GA
Jim/GA's Avatar
There are instructions in the original Ford Dealer Service Bulletins on how to adjust this style brake system with the equalizer (and no separate parking brake system). Follow them. Reprints are available.
Mechanical brakes DO stop your car well, when done right. I can skid all 4 tires on both of my Model A's on clean dry pavement.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 06-13-2018, 08:29 AM   #8
46woodduck
46woodduck's Avatar
As the old guy I worked for in high school 56 years ago told me..."when all else fails, read the manual". After all of these years I still go to the books when problems arise.
Life is good on the lunatic fringe.
46woodduck is offline   Reply With Quote
Old 06-13-2018, 07:13 PM   #9
upd8922
Members,
Thanks for the comments. We were able locate and correct the problem. Apparently the rods were bent and straightened out. The brakes work fine.
