Old 11-29-2010, 03:41 PM   #1
MrTube
MrTube's Avatar
Default horn polarity?
Just hooked everything up. As far as I can tell the horn doesn't seem to care about polarity. is this correct?
Also curious if anyone has a good picture of how the stock wiring harness goes from the switch housing to near the radiator. I have it slipped up in between the shell and radiator on drivers side. Seems to look correct but I want to be sure.
MrTube is offline   Reply With Quote
Old 11-29-2010, 03:47 PM   #2
Gary WA
Gary WA's Avatar
Default Re: horn polarity?
yes on the horn.wire goes behind rad bracket to horn, light across lower rad, should have 3 clips on bottom of rad to hold wire to right head light.
Old 11-29-2010, 04:16 PM   #3
Glenn C.
Glenn C.'s Avatar
I don't think the polarity makes a difference, otherwise the contact points would be identified for such.
If they do.....I goof up every time I connect the wires to the horn.
Glenn C. is offline   Reply With Quote
Old 11-29-2010, 05:44 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Since the horn motor is series wound, polarity doesn't matter. When the armature polarity is reversed (by swapping the 2 wires under the horn clips) the field polarity will be reversed also, so the armature will still spin in the same direction.
