Old 07-30-2022, 11:44 AM   #1
V8guy
Default PSI for block testing
What is the recommended PSI for pressure testing for block testing ?
Thanks
V8guy is offline   Reply With Quote
Old 07-30-2022, 12:06 PM   #2
glennpm
glennpm's Avatar
Default Re: PSI for block testing
My opinion, 10 or 15 psi and then if you use a pressure radiator cap, keep it at 8psi.
Do not test this with only air. You have a very dangerous "bomb" if it fails. Fill with water and then either air or water pressure or the top
Old 07-30-2022, 09:01 PM   #3
flatjack9
flatjack9's Avatar
I fill with water and test at 50 psi.
Old 07-31-2022, 05:24 AM   #4
flatford8
flatford8's Avatar
I’ve been reading about pressure testing blocks for a few years......this is the first time I’ve seen anything about filling them with water first......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 07-31-2022, 06:36 AM   #5
sugarmaker
sugarmaker's Avatar
Folks,
Well, for sure I am not a expert to speak on this subject. Only stood by when my B block was air presure tested to 60 PSI at my machine shop. No water in block. That is only one ref point and no supporting data for appropriate testing methods of blocks.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 07-31-2022, 07:24 AM   #6
Oldtmtech
Oldtmtech's Avatar
Being an old tractor guy I can tell you all steam boilers are hydro tested meaning the boiler is filled with water then air pressure the reason being is because water does not compress so if you have a leak the pressure quickly drops because your air vessel is small
If you just filled it with air pressure and you have a leak it is like when you lose a hose off of your air compressor tank and the hose whips around for ever
Your air compressor tank is a certified pressure vessel your engine block is not
Kind of a crude explanation but I hope this helps
Todd
Oldtmtech is offline   Reply With Quote
Old 07-31-2022, 07:29 AM   #7
Frank Miller
Frank Miller's Avatar
I know a gut who stitches blocks and he tests to 30psi which is twice the pressure any pressurized system sees.
Air tanks I believe, are routinely tested with water but these are done at much higher pressures. I suppose testing with water in the block will help you identify any cracks by visible wet spots.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 07-31-2022, 07:31 AM   #8
Bored&Stroked
Bored&Stroked's Avatar
I use air pressure at about 30 - 40 PSI. I like air as I then spray soapy water all over the block and into the ports to look for bubbles. Trust me, the bubbles will show you exactly where there is a hole, crack or other issue - and it is a very SAD experience to see them . . .
Old 07-31-2022, 09:24 AM   #9
D. Jones
D. Jones's Avatar
A friend gave me the basic motor I have in my truck because a guy that was going to buy it pressure tested it at 165 psi and blew a pea sized hole on the #5 intake valve-guide pocket. The fellow brought the motor back and told my friend what he had done. My friend was so mad he rolled the motor out on to the ground and left it there for about two years before he gave it to me. Fortunately I was able to engineer a repair that worked.
Pressure testing is good if not carried to extremes.
D. Jones is offline   Reply With Quote
Old 07-31-2022, 11:37 AM   #10
glennpm
glennpm's Avatar
Todd
Exactly correct Todd.
Old 07-31-2022, 12:44 PM   #11
Tim Ayers
This is great info. I just bought a pressure testing kit and was wondering
Old 07-31-2022, 04:45 PM   #12
Yoyodyne
Yoyodyne's Avatar
How much pressure can you put in an early block without popping out the core plugs in the pan rail?
Yoyodyne is offline   Reply With Quote
Old 07-31-2022, 05:27 PM   #13
Phil Gillespie
Phil Gillespie's Avatar
1.5 times normal working pressure is a safe margin as I have been advised.
2 times normal working pressure would be the maximum for safety.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 07-31-2022, 06:28 PM   #14
flatford8
flatford8's Avatar
I have a pressure test kit from Speedway. I put a shutoff before the regulator, then my air fitting. I read that one of the well known contributors here (can’t remember which one) used 55lbs as his test pressure. I set my regulator at 55, shut off the supply and unhooked my airline. An hour and a half later it was still at 55lbs. Did both sides this way. As I said before, never read anything about filling the block with water first......Mark
Billy Joe Shaver
Old 07-31-2022, 06:42 PM   #15
flatjack9
flatjack9's Avatar
I've never blown one with 50 psi in over 20 years.
Old 08-01-2022, 07:06 AM   #16
Frank Miller
There are two completely different schools of thought going on here. Pressure testing steam boilers and air tanks is completely different than pressure testing a block.
A high pressure vessel like a steam boiler gets tested at extremely high pressure where a failure would be catastrophic with strictly air. Not to mention it is easy to achieve a much higher pressure with water - think hydraulic brakes - than it is with air.
A block that wil see no more than 15psi on a closed system will easily pass at 30psi.
nothing wrong with 50 either. Anything higher is completely unnecessary.
