08-17-2018, 02:30 PM | #21 |
Re: Jerky Runner
I do: glug-glug-glug-glug whenever I get gas. Not going to hurt a thing.
Paul in CT |
08-18-2018, 09:43 AM | #22 |
Re: Jerky Runner
I once saw some "JERKY RUNNERS", while running, they were talkin' to one another, on their CELL PHONES!
Bill Babble
08-20-2018, 07:12 AM | #23 |
Re: Jerky Runner
I had a similar problem on one of mine (was not running smoothly), but was not backfiring. I tried a number of things, and what finely worked for me was to reset the valve clearance on all the valves.
08-20-2018, 01:48 PM | #24 |
Re: Jerky Runner
Ben, this also could be my problem. I did try to adjust the valves awhile back. But I was having a problem with one of the adjustable valves and I may have messed it up. So I may need to try adjusting them again.
08-20-2018, 01:52 PM | #25 |
Re: Jerky Runner
I see them (cell phones) in my living room. They aren't jerky in their actions but they are "Jerks". Forgot how to communicate in this environment.
09-25-2019, 05:52 PM | #26 |
Re: Jerky Runner
So I did some thinking about the situation as to what it was doing--- would "miss" when pressing on the gas starting out from a stop. Well so many people recommended Marvel Mystery Oil so I got carried away. A few days ago I took the plugs out, dumped in a bunch of MMO in each cylinder, and let it set for a few days. Today I got in it, started it up(and it did start) and I had a concern that the neighbors would call the fire department. So I backed outside and let it run for awhile blowing smoke all over the neighborhood. Then I got in it and drove it around the block a few times in 1st and 2nd. At first it still had the problem. Then after a few rounds it all cleared up-smoke and the jerk (not me). After parking it after a few miles, I turned it off and let it set for while. They I tried to start it. I had spark up, gas lever up and just a touch of the starter, it was up and running! Wow! This start was better that it had done for years. I also pulled one of the spark plugs and looked at it. Before the MMO, when I took them out they were covered with black junk. This time the electro look nice and brown and no black stuff. Anyway to sum up all these comments- it does look like I had a stuck valve. Putting the MMO in the cylinders and running it after that did clear up the problem of a jerky start where it would jerk and backfire in the carb. Hope this helps someone.
Fred Kroon 1929 Std Coupe 1929 Huckster Last edited by Fred K-OR; 09-25-2019 at 09:55 PM. |
09-25-2019, 06:11 PM | #27 |
Re: Jerky Runner
Thanks for the come back and final report. MMO seems to be a common cure and should always be the first step in solving performance problems. Go drive it like you stole it !!
09-25-2019, 06:18 PM | #28 |
Re: Jerky Runner
Glad it worked out for you Fred. This tells me that you need to start looking for more parades during the year. And for what it is worth, i always add about 4 oz of MMO every time i fill up on both of my A's. Mark.
09-25-2019, 07:15 PM | #29 |
Re: Jerky Runner
Mark, the MMO idea sounds good. Will have to do. But I think the parades may go. Hard on the old rig, clutch etc. So think I will watch parades instead of being in them!
09-25-2019, 07:40 PM | #30 |
Re: Jerky Runner
I am with you on that Fred. I use to do two different Christmas parades for a few years, but now i find a fold out chair and a cup of coffee just seems to fit me better. Mark.
09-25-2019, 09:58 PM | #31 | |
Re: Jerky Runner
09-26-2019, 02:43 PM | #32 |
Re: Jerky Runner
Your real problem is either wrong or faulty plugs, or most likely, your running to rich and idling to much.
09-26-2019, 05:06 PM | #33 |
Re: Jerky Runner
Is the ignition cable an original one ? I had a very similar experience recently with my car, and finally diagnosed the problem as an intermittent short inside the cable conduit. the wire inside was almost 90 years old and the insulation was badly cracked and falling off. Found this only after rebuilding the distributor and replacing the coil.....all the parts I replaced were working just find. Checking the ignition cable never occurred to me.
10-11-2019, 05:41 PM | #34 |
Re: Jerky Runner
Well I took the old jerky runner out for a drive today. About 2 weeks after the MMO treatment in the cylinders. It started better than it ever did, after warming up (46 degrees around here today) and ran like it should. No jerks and good pickup. So I again would guess that I had a stuck valve or it may have be very sooty spark plugs that cleared up with the MMO. But I am no experts on this type of thing but this is what it seemed like to me.
10-11-2019, 09:07 PM | #35 |
Re: Jerky Runner
Good to hear Fred. Depending on the weather, you just might have to get it out and drive it a little more often. Take the wife out to breakfast or lunch or dinner. Or maybe all three. Good luck with it and have a great weekend. Mark.
10-12-2019, 08:20 AM | #36 |
Re: Jerky Runner
The two most common problems that can happen after a car sets for a time is fuel deterioration and sticking valves.
Fuel doesn't last very long unless it is a higher quality formula like 93 octane premium. Avgas last a lot longer but it's overkill on a model A and it's not legal to run it in cars. Draining the fuel is a PITA but sometimes it's the only way to insure a clean fuel system. MMO and running the engine regularly are the best way to prevent sticking valves. I wouldn't use any more MMO than is necessary. This isn't a 2-stroke engine and they generally get enough blow by to keep the piston rings lubed up. They don't run well on oil and solvent alone. It doesn't take all that much MMO to do the intended job. We run the aircraft engines every 2-weeks if they are in flyable storage. This is considered the minimum interval for safe flight. Even 2 months is too long. |
10-12-2019, 06:21 PM | #37 | |
Re: Jerky Runner
I use no crap gas in my rigs and that seems to work out great. So I think in the future I do need to use the MMO as you mentioned. Because I do leave my rigs in the shop for long periods of time and don't run them enough.
10-13-2019, 09:11 AM | #38 |
Re: Jerky Runner
Don't feel alone about that. Folks don't always have time or weather that coincides with opportunity. I have helicopter customers that let them set far too long. It's what keeps money in my pocket though but I worry about them too.
