Old 12-28-2010, 10:34 AM   #1
Hunter
Default Conduit Clip at Firewall
Does someone have an image of the clip that is used to hold the metal wiring conduit to the firewall.
I noticed the reproduction clips have "two legs" that the conduit snaps in between. I have had I think to be a couple of original clips and these do not have the two legs but have a C shape that simply goes over conduit.
Which is correct?
Hunter is offline   Reply With Quote
Old 12-28-2010, 11:10 AM   #2
Steve Plucker
Default Re: Conduit Clip at Firewall
The one with "two legs" (A-14576: Terminal box to generator conduit clip--upper)...it is a special clip unlike the ones that holds the speedometer cable to the fire wall AND the one (A14577:Terminal box to generator conduit clip--lower) that attaches the metal conduit to the A-8275 Cylinder Water Inlet Connection. These two are the same for 28-29 early 30 BUT somewhat different for mid 30-31 (I think) Sorry...no photo.
Pluck
Old 12-28-2010, 01:49 PM   #3
Charles Reese
Charles Reese's Avatar
OK, ignore the modern plugs! Trying to show the '2 leg' clip for Hunter ...
Charles Reese is offline   Reply With Quote
Old 12-28-2010, 04:58 PM   #4
Hunter
Hi Charles
Thanks - Hunter
