10-21-2014, 12:10 PM | #21 |
Re: Front brakes advice
Purdy,
Wow! That backing plate looks like it got some wear on it at one time from the brake pin at the spindle bolt. Loose BP? someone grind to compensate for something? Kind of an unusual wear pattern All the best! Larry |
10-21-2014, 12:16 PM | #22 |
Purdy,
A million thanks for advice and pics. Understand everything you have said. Will blow dry bearings gently. Got the reason for chamfer, but how do you do that? A grind wheel, file, take to machine shop, or other? Thanks for warning that Andrews manual is not the last word. Yes, I regularly refer to both Snyders and Brattons for diagrams. Will examine the lower brake tracks just as you advise. Only problem is I am a ... "Girl without welding torch" |
10-21-2014, 12:33 PM | #23 |
Larrys40, I appreciate your advice and words of caution. I am eager to do as much as I can, but have a local guru on speed dial for guidance. The great thing about this site is I can learn so much here. Then when I have a question for the guru, I don't feel like a dim wit when talking to him. Saves getting on his nerves!
10-21-2014, 12:42 PM | #24 |
,Larry, The tracks were ground with the tracks still riveted to the backing plate as it came from the factory. I think that the marks that you see is where the wheel on the cutoff tool that I used to level the tracks got against the backing plate when I ground the tracks. It was hot the day that I did them and I was in a hurry. It is just sloppy work but won't effect brake action and would be hidden when the shoes are installed. I only do my stuff and none of mine are show cars . I just posted this pic because it was handy and would give Wrench Girl an idea how the tracks need to look to avoid shoe drag against the bottom of the drum.
10-21-2014, 01:07 PM | #25 | |
10-21-2014, 01:18 PM | #26 | |
Place a golf ball size lump of wheel grease in your off hand. Then place bearing to be packed on the first finger of primary hand and hold in place with thumb. Cup off hand and pull bearing thru EDGE of grease..till grease shows up thru bearing. Then turn bearing quarter turn and repeat operation till bearing is FULL. When ready to install, I then coat outside of bearing liberally with same grease and install. I now use surgeon/latex/whatever gloves. Makes it easier on hands and less messy, as can change gloves often . Luck to you. BTW...many are telling you good info about checking everything in brake system, especially with what was found in this one area. That to me is a given. I tried to stick with you question and immediate situation,eh |
10-21-2014, 01:33 PM | #27 |
I always hand pack the bearings just as hardtimes said, except I use an old bread bag on my left hand. When the bearing is packed full I can just leave the bearing in my left hand and turn the bag inside out with the bearing inside. This way it's protected from dirt and bugs until it's needed.
I want my tracks to run straight, so I weld and grind as Purdy said. If you bend them, the brakes will move up or down as they wear and move outward. I have never tried to bend the tracks, but it seems like it would be very tough to do. |
10-21-2014, 04:01 PM | #28 |
To check for potholes in the cone inner race, just GENTLY pry out 1 roller, with a small screwdriver. It can be tapped back in, using a small brass hammer. All new bearings are a good idea, but they're EXPENSIVE!
Use a quality brand, HIGH TEMP DISC BRAKE GREASE! All greases are NOT equal, don't use "ACME" grease that was formulated for wagon wheels & RADIO-FLYERS! Bill W.
10-21-2014, 05:23 PM | #29 | |
Yeah, I've used your bread bag/plastic shopping bag idea often, until I found that the hospital type glove are cheap for 100 count....and I also roll them of onto the bearings as well. Even cheaper, a box of 500 ..called the 'clean ones'. Pollyethlene (thin tough plastic...like a clear see thru glove). I use these for even food prep, oil / grease changes and of course bearing packing /holding ! These are ideal for cheap model a guys, who won't pop for the surgical gloves ! BTW..for those who are younger and maybe still with good hands. You will eventually find out why old guys use hand protection when doing gas/oil/grease jobs ! |
10-21-2014, 06:16 PM | #30 |
I recently rebuilt my brakes: woven shoes, cast drums, new rods and clevises/pins. I can agree with all of the above posts. I can only add it is so important to be sure your brake shoes are centered on the axle. This will require a brake centering tool. I find the best brake centering tool is sold by Snyder's. I used a tight fitting deep socket with an extension when I needed to adjust the roller tracks. You will get the same result as indicated above regarding the nickel and quarter if your brake shoes are not centered. Be patient and good luck.
10-21-2014, 10:53 PM | #31 |
A friend cut away most of a front & rear brake drum & mounted a cheep dial indicator on the outside & it is a dandy centering tool! He welded a sleeve, with a bottoming ring, on the outside of the drums & the dial indicator just lifts out, to switch from one shoe to the other.
Bill W.
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 10-21-2014 at 10:55 PM. Reason: FORGOT A COMMA |
10-22-2014, 10:31 AM | #32 |
Great idea about using plastic bag or nitrile glove to pack the bearing, then turn bag or glove to wrap up the bearing. Genuinely a NEAT trick. Thanks.
10-22-2014, 11:05 AM | #33 |
You mean like this??
10-22-2014, 02:48 PM | #34 |
I'm with Purdy and Tom. I hadn't even heard anyone mention 'Arcing" brake shoes for a long time, until I got into Mod. A s. Like Purdy, I chamfer both ends of the shoe material as I install it. Not only on mod A s either. All my brake jobs. It helps with the fitting of the shoe to the drum. But I will say this, Take the new shoe and place it into the drum and just visually check the match of the shoe to the drum. It's usually off a little. If it's off a lot, maybe someone sold you the wrong shoes.
Terry |
10-22-2014, 04:33 PM | #35 |
Terry is right its best to lay the relined shoe inside the drum that you plan to use and see how it fits. If its off that much it is probably time to find better drums. Trying to arc shoes to a badly worn drum will just sand away most of the lining and still may not match up. There is oversize lining and reinforcement bands that can be used on steel drums.
10-22-2014, 09:47 PM | #36 |
[QUOTE=Terry,NJ;967278]I'm with Purdy and Tom. I hadn't even heard anyone mention 'Arcing" brake shoes for a long time, until I got into Mod. A s. Like Purdy, I chamfer both ends of the shoe material as I install it. Not only on mod A s either. All my brake jobs. It helps with the fitting of the shoe to the drum. But I will say this, Take the new shoe and place it into the drum and just visually check the match of the shoe to the drum. It's usually off a little. If it's off a lot, maybe someone sold you the wrong shoes.
Terry[/QUOTE The drums are probably TOO BIG!! Bill W.
10-23-2014, 09:42 AM | #37 |
Thanks everybody. I'm reading all the advice. Will tackle the job this weekend -- well, at least get started. Stay tuned for lots more questions.
Girl with drop light |
