Old 04-23-2024, 02:59 PM   #1
Heard
Heard's Avatar
Default Parking brake disassembly
Can anyone instruct me as to how to disassemble the parking brake handle on my '35 pickup. This is the handle with the spring loaded push button at the top. I want to refurb this thing but I don't see how that springy thing comes apart.
Thanks,
Heard
Do I look like I have a plan B?
Heard is offline   Reply With Quote
Old 04-23-2024, 07:54 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Parking brake disassembly
Thanks,
Heard
IF you'll post a couple of pictures, WE can figure it out, like MOST crap. Maybe a couple to my e-mail, too.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 04-24-2024, 10:52 AM   #3
rich b
rich b's Avatar
Slide the handle off the pawl/mount, push the rod into the lever from the bottom, press the little pin that is now accessible out of the button, pull the rod and ratchet out of the lever, and finally pull the spring out of the recess on the top of the lever.
Be careful if the pin or button is stuck as the rod can break where the pin hole goes thru it.
Sometimes the spring (or part of the spring if broken) can be stuck in the recess. A tap screwed into the spring can give you a handle to pull it.
Old 04-24-2024, 04:26 PM   #4
Heard
Heard's Avatar
Thanks Rich!
Old 04-25-2024, 09:12 AM   #5
Planojc
Planojc's Avatar
Rich has it correct, the main thing holding it together is that pin on the button.
Planojc is offline   Reply With Quote
Old 04-25-2024, 05:47 PM   #6
Heard
Heard's Avatar
Well, I got it apart thanks to Rich. That is a very small pin in that button.
Thought I'd post a pic in case anyone else needs this info.
Heard
Old 04-25-2024, 06:28 PM   #7
petehoovie
petehoovie's Avatar
Heard
Old 04-25-2024, 10:21 PM   #8
1952henry
1952henry's Avatar
To the rescue ^^^^. Thanks for the pictures. Had no idea about those. In my future down the road.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
