Old 03-13-2024, 02:38 PM   #1
Ol' Ron
Ol' Ron's Avatar
Default Cleaning out my cams
Going threw my old cams looking for the 300 jr I had in the stockcar I ran across a weber caO4oX with .402 lift. Don't my setup together to check duration and was wondering if Pete might have a list of weber cams better than the old advertizing one I have.
Thanks Granps
Old 03-13-2024, 02:46 PM   #2
Pete
Pete's Avatar
Default Re: Cleaning out my cams
Thanks Granps
Sorry, nothing on Weber here.
Old 03-13-2024, 03:22 PM   #3
Tim Ayers
Ron,
Can you double check that number? I think any Weber with an X at the end indicates it is a radius lifter cam.
Old 03-13-2024, 07:04 PM   #4
34fivewindow
34fivewindow's Avatar
Weber F4 is 282 duration and 340 lift.
34fivewindow is offline   Reply With Quote
Old 03-13-2024, 08:19 PM   #5
Ol' Ron
Ol' Ron's Avatar
Yes, the lift is what threw me off, that's alote of lift for an old cam. I'll clean it up and have my daughter read the numbery, much newer eyes.
Gramps
Old 03-13-2024, 09:21 PM   #6
Bored&Stroked
Bored&Stroked's Avatar
My first "hotrod" flathead was 284 cubic inches and had a Weber F6 cam in it. The cam sounded good, but I wasn't terribly happy with it (just ran out of power too soon). I then swapped over to a Potvin 425 Eliminator . . . now that was a lot better . . . ran that with three Holley 2110 carbs (they flow about 30% more than a 97).
Then I went to a cam that Tom Hutchinson called the "awful awful" (don't know the actual grind numbers/letters) - an Erson grind with .450 lift and a ton of duration - and added a blower. Now that was the cat's ass. LOL
Didn't really want to idle below about 1200 . . . but it was fun! LOL
Old 03-14-2024, 04:12 AM   #7
Tim Ayers
If I recall correctly, I believe Ron used that cam as well after the 400Jr.
Old 03-14-2024, 01:58 PM   #8
Ronnieroadster
Ronnieroadster's Avatar
We all have had a degree of learning by way of cams over the years. My little 258 blower combination on the street ran strong with a Potvin 3/8 super we figured it was making a good 300 HP. Same engine testing in my 3000 pound race car at the 1.5 mile speed trap ran 171MPH at the timers. Another great cam I ran and still have is the Crane R-450 anything over 450 lift would be to big to fit threw the flathead cam bearings so that was the limit from what I know.
Another good choice I used many times was the old reliable L-100 ground using the original
Laterio cam grinder and master. And lastly from the good old days I ran the Potvin 425 ground on the 32 steel cam. Don't know where that one ended up can't find it in my stash of stuff!
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 03-14-2024, 02:31 PM   #9
flatjack9
flatjack9's Avatar
I believe you are right Tim.
Old 03-14-2024, 06:27 PM   #10
Ol' Ron
Ol' Ron's Avatar
No, this iz just one of the cams I had in the junk pile. The Sig Erson D410 replaced the 400jr. Went Threw a few more today, but didn't find anything worth talking about. Too cold to stay too long in the shop, so i skipped out I was thinking of setting up sablock to check duration as well but haven't found any interesting cams yet!!
Gramps
Old 03-14-2024, 06:30 PM   #11
Tim Ayers
Speaking of old cams, curious if anyone has ever used a grind from Racer Brown?
Old 03-14-2024, 06:51 PM   #12
Pete
Pete's Avatar
Yup. We had a Super Torque 2 in our home made 4 cylinder Chev in our midget.
Excellent grind. Very high lift velocity.
Old 03-15-2024, 11:01 AM   #13
Ol' Ron
Ol' Ron's Avatar
RR I used an L-94? In an engine when I had a few and wish I had it back. Much better street cam. Same sound but more low end torque. You probably have the specs there someplace. I misplaced mine along time ago/
Gramps
Old 03-15-2024, 01:16 PM   #14
John R
Taking inventory of my cams, I ran across a NOS Wolverine #933. Seems like a pretty useless grind with 280/268 duration and 52 degrees overlap with only a .320 inch lift.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 03-16-2024, 10:43 AM   #15
Ol' Ron
Ol' Ron's Avatar
John R, Sounds like a good street cam. Good low end torque and fuel mileage. Think Application With the cost of changing the cam. aesthetics are too expensive.
Gramps
