Old 05-28-2010, 05:25 PM   #1
rfv60
Exclamation 223 6cyl rocker shaft oiling
customer has 50's ford pu with oil supply problem to rocker shaft. need help locating online a diagram of oil system. do not have repair manual handy and vehicle is located 20 miles from shop. would like to know what to expect when i go on road trip. have installed external oil kits on early ford engines back in the 60's and suspect this has same type of obstruction. if kit of this nature is needed where to purchase? thanks richard
rfv60 is offline   Reply With Quote
Old 06-06-2010, 09:28 AM   #2
dga1028
Default Re: 223 6cyl rocker shaft oiling
My motors manual shows oil up to shaft thru next to last support stand and return thru the others. Do not recall this engine but some had a special bolt it supply position.
dga1028 is offline   Reply With Quote
