08-22-2015, 07:44 AM | #1 |
LED tail lights
I was wondering your opinion on 6 volt LED tail / directional lights. I'm always nervous I'm going to be hit from the rear when turning. Also my front directionals are in the cowl lights and was thinking of putting and amber bulb in there if they are available.
08-22-2015, 07:52 AM | #2 |
Re: LED tail lights
I put 6V LED tail lights in my roadster and was amazed at how bright they are. They are available from any of the Model A suppliers and look exactly like the original lenses. You will likely have to put resistors in the lines to make the flasher operate properly.
Glen
'31 Model A Deluxe Roadster '31 Chrysler Model 70 Sedan '88 Pontiac Fiero GT '36 Auburn Boattail Speedster replica |
08-22-2015, 11:12 AM | #3 | |
Re: LED tail lights
08-22-2015, 11:21 AM | #4 | |
Re: LED tail lights
"... I just added 10W front turn bulbs [cowl]..." |
08-23-2015, 12:22 AM | #5 | |
Re: LED tail lights
Search the net for 6v solid state flasher and pick the configuration you need. EF-32 for a 2 terminal flasher, or EF-33 for a 3 terminal for 12 volt but Tom Wesenberg says they will also work with 6 volts..
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 08-23-2015 at 12:36 AM. |
08-22-2015, 08:30 AM | #6 |
Re: LED tail lights
08-22-2015, 11:25 AM | #7 | |
Re: LED tail lights
08-22-2015, 09:27 AM | #8 |
Re: LED tail lights
Don't wait, install them. A modern driver on the road would most likely look for your front turn signal light at your bumper. Not saying cowl light isn't bad but you might have a faster reaction from the bumper location from most drivers
08-22-2015, 09:32 AM | #9 |
Re: LED tail lights
Hi Billy,
Also, the horizontal LED rear window brake light is an "eye level", eye opening safety device when Model A brakes are applied. Much added safety, especially on rare occasions such as driving on a foggy and/or a misty night .................................................. .. or even with something we "rarely" see .................................... some young driver not paying attention while texting a message on his cell phone. |
08-22-2015, 09:57 AM | #10 |
Re: LED tail lights
I don't run LED's but have replaced the A lights with those from a 1936, they are the same diameter but have a single lens, thus giving a bigger light for others to see. Not good for Model A judging but very important on a driver.
08-22-2015, 10:44 AM | #11 |
Re: LED tail lights
There has been much written about this subject here, so its probably in search or archives.
That said, I've installed them. Didn't want to, but, after being rear-ended I decided it was time. They work well and are much brighter, but, resistance needs to be added to fire the thermal flasher. I just added 10W front turn bulbs [cowl] which works nicely as they are also much brighter. Much has been said about electronic flashers, but, I've tried 3 different spec ones and could not get them to work. Some have added resistors with the bulbs, but, I didn't as the higher wattage bulbs are all thats needed. Last edited by Patrick L.; 08-31-2015 at 09:51 AM. |
08-22-2015, 04:56 PM | #12 |
Re: LED tail lights
I put it on my '28 Leatherback. I thought it was a good idea especially since I only have the one tail light. They are bright and do the trick.
1929 Model A Ford Coupe |
08-22-2015, 05:34 PM | #13 |
Re: LED tail lights
I regard my 3rd brake light as a life saver. It is mounted in the middle of the luggage rack and I get plenty of coments fro other drivers about how bright it is. Obviously, it works! There is only the occasional complaint from the following driver having black spots in front of his eyes for a week later.
08-22-2015, 05:57 PM | #14 |
Re: LED tail lights
Get you a led flasher from superbrightleds.com they will work your LED lights.
'40Garage |
08-22-2015, 07:00 PM | #15 |
Re: LED tail lights
I have lights under the body that are noticable when lit, and also the LED in the rear window that is both a stop lamp and turn signals. The original drum taillight is mostly for decoration.
08-22-2015, 07:16 PM | #16 |
Re: LED tail lights
LED lights are very much brighter than incandescent bulbs and take a lot less current to make them work. Like the idea of having things as bright as possible for other drivers to see. IMO the turn signal lights in the parking lamps are in a place that most drivers are not looking for, so the ones on the bumpers is better. Also the ones in the headlight are over powered by the headlight. The third brake light is also an extra measure to warn the driver in the rear that something is happening as a lot of drivers do not pay attention. The resistor that folks talk about are usually installed on the circuit boards of the LED lights. The resistors are required to make the old style flashers work as they require a certain amount of current to make the bi-metallic strip heat up and open to make the lights go on and off and the LEDS do not draw enough current to make this happen.
08-22-2015, 11:07 PM | #17 | |
Re: LED tail lights
Biggest need to be seen is for the folks following. I am watching the one coming the other direction. Most moderns have the turn signals right beside the headlights. Are they "over powered"? |
08-23-2015, 07:20 AM | #18 |
Re: LED tail lights
Yes, when the headlamps are on with many modern cars, it is difficult to see the turn signal until they are quite close. I have noticed this for a few years now. This is mostly a problem when the lights are on in the daytime.
08-30-2015, 10:27 PM | #19 | |
Re: LED tail lights
08-23-2015, 04:00 AM | #20 |
Re: LED tail lights
I found 6 volts to be the very bottom limit for my EF-32, so if your engine is idling and the headlamps are putting the ammeter in the negative area and the voltage reaching the flasher falls below 6 volts, they may stop flashing until the engine is revved up a little. I've only bench tested them so far, but they do work fine for me.
