Old 09-25-2010, 05:52 PM   #1
roddyb34
roddyb34's Avatar
Default AA Bellhousing
Can anyone confirm that the AA bellhousing dosent have pivot shaft for pedals and they are shorter than car unit ,thanks from Rod ,,
roddyb34 is offline   Reply With Quote
Old 09-25-2010, 05:56 PM   #2
James Rogers
James Rogers's Avatar
Default Re: AA Bellhousing
AA bellhousings do not have the pedal shaft. It is on the transmission. The bellhousing is 1" shorter than the standard Model A housing.
Old 09-25-2010, 05:58 PM   #3
roddyb34
roddyb34's Avatar
Thanks James,
Old 09-25-2010, 10:52 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
The AA also uses a shorter hub for the throwout bearing.
