11-24-2022, 10:34 PM | #1 |
48 merc ignition
Can someone tell me how many lugs are on the back of the ignition switch and where they go.
11-25-2022, 11:23 AM | #2 |
Re: 48 merc ignition
I'm not certain but pretty sure there are four. The feed or BAT, the accessory ACC, the ignition IGN and the starter STR. So the BAT is incoming power from the battery, the ACC is all your accessory's , heater , radio and such. the coil is the only thing on the ING lug and the starter solenoid is all that should be on the STR lug if it has one(if you have a starter button you wont have this lug)
Tim |
11-25-2022, 12:09 PM | #3 |
This was the first year that Ford started using a dash mounted switch. The previous years only had the ignition involved with the switch on the steering column. Bat, Access, and Coil are likely the only terminals. Start function was independent well into the early 50s. The accessory power was primarily for the instrument panel. Battery is power in and coil is ignition only. Lighting was all still independent of the ignition switch. The radio sets had their own fuse if installed so it could be added to the battery terminal or accessory if there is room on the terminal. Most cars that had radio would be connected to the battery terminal so that the it could be independent from other current draws.
11-26-2022, 09:30 AM | #4 |
OK Thanks that helps. Where did the start button get power. Was one side of it fused direct to the battery or from the ignition switch?
11-26-2022, 11:00 AM | #5 |
The start button gets a feed from the start terminal on the solenoid and grounds it to the body to pull in the solenoid.
It's the opposite of what would become the norm in later models. |
11-26-2022, 12:12 PM | #6 |
11-26-2022, 12:44 PM | #7 |
11-26-2022, 04:09 PM | #8 |
It should be understood that SOME (if not ALL) '48 Mercurys had a new, dash-mounted key switch, unlike the older, square, Bakelite switches mounted on the column drop, as depicted in this drawing from Mac VP's library. I have read literature indicating that the '48 Merc ignition switches were the same as '49 Ford. I BELIEVE that the picture BELOW is the rear of a '49 Ford switch with three terminals, same as the '47 and earlier switches had three terminals. It would make reasonable sense that they function the same, electrically. The switch in the drawing shows the power coming in from BATTERY. Then, it shows one of the other two similar-looking connections to feed the ignition resistor. The second of the two similar-looking connections feeds a buss bar connecting gauges. Looking at the '49 switch ABOVE, it appears that the top connection (it's different appearance easily discernable from the other two) is battery power from the solenoid. The use of a simple volt/ohm meter should differentiate which of the remaining two SIMILAR poles is IGNITION, and which is ACCESSORY for the gauges. Coop . Last edited by V8COOPMAN; 11-27-2022 at 02:41 PM. |
11-26-2022, 04:43 PM | #9 |
V8COOPMAN ….
FORDs also right …? Not just Mercs….. My Ford has that same switch … Just making sure……
Whether you think that you can,or that you can't,you are usually right....H.Ford |
11-26-2022, 06:29 PM | #10 | |
Wudy,,,, The '48 Ford appears to be the same as Merc. Coop |
11-27-2022, 11:10 AM | #11 |
Hey, thanks you guys. This a big help, especially the picture and diagrams.
