Old 03-28-2024, 05:44 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default 54 mercury electric fuel pump question
What gauge stranded wire should be used to wire a 6 volt electric pump on the vehicle???
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 03-28-2024, 05:52 PM   #2
KULTULZ
KULTULZ's Avatar
Post Re: 54 mercury electric fuel pump question
Where are you placing the pump? AMP of the pump?
See if this helps - https://www.wirebarn.com/Wire-Calculator-_ep_41.html
Did you get my last PM?
KULTULZ is offline   Reply With Quote
Old 03-28-2024, 08:55 PM   #3
Bob from Northport
Default Re: 54 mercury electric fuel pump question
Yes. I got your last PM. I read everything.
I can NOT find any amp rating on the pump. Its the one you recommended-an AUTOKAY 6 volt pump.
It is being mounted on the frame just in front of the left rear wheel, as far back as I can get. I have a bypass built around it just in case.
I was an electrician most of my life. I understand voltage drop and amperage.
I was just asking what you or anyone used to wire a pump up. 16 or 14 gauge stranded??
Bob from Northport
Northport, Michigan
Old 03-28-2024, 10:52 PM   #4
miker98038
miker98038's Avatar
Ha, another retired electrical guy. Like me. You’ll probably be good with 16, but I’d use 14 just to be safe. I had an electric pump (in a very off topic installation) that was a Bosch. Said it would support up to 930hp in a turbo 911. I used #10 for that one.
I’ve got in tank GM pumps on 2 yblocks. One supercharged, one a throttle body EFI. 40# or so. They’re both on #12. So 14 should be safe.
miker98038 is offline   Reply With Quote
Old 03-29-2024, 02:31 AM   #5
KULTULZ
KULTULZ's Avatar
Arrow Re: 54 mercury electric fuel pump question
Do you have the thread where I let my mouth overload my a$$?
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
Old 03-29-2024, 08:16 AM   #6
Bob from Northport
Yes
Bob from Northport
Northport, Michigan
Old 03-29-2024, 10:41 AM   #7
KULTULZ
KULTULZ's Avatar
Can you post it so I can see what I posted?
Old 03-29-2024, 11:17 AM   #8
Bob from Northport
I don't know how to do that.
Bob from Northport
Northport, Michigan
Old 03-29-2024, 12:44 PM   #9
miker98038
miker98038's Avatar
That name comes up in this thread, and a link to Amazon. Based on the picture that looks like pretty light gauge wire. I’d go up 1 size for the feed and fuse accordingly. But it’s not one of Kultulz’s post.
https://www.fordbarn.com/forum/showt...hlight=AUTOKAY
Old 03-29-2024, 01:18 PM   #10
KULTULZ
KULTULZ's Avatar
Thumbs up Re: 54 mercury electric fuel pump question
THANX! for that Mike.
I didn't remember suggesting a pump by name. Just trying to CYA here ...
Too damn poor to cover a bond ...
BTW - AIRTEX was bought/absorbed by CARTER.
Old 03-29-2024, 05:41 PM   #11
Bob from Northport
My mistake. Sorry for the confusion. I found the thread. Go to search and type in adding a electric fuel pump . Merc Cruiser made the recommendation..
Bob from Northport
Northport, Michigan
Old 03-30-2024, 08:57 AM   #12
KULTULZ
KULTULZ's Avatar
No big deal. I try and not recommend brands as if it comes back on me, I will be a bigger SOB than I am now ...
Old 03-30-2024, 10:53 AM   #13
Bob from Northport
still lots to learn
Bob from Northport
Northport, Michigan
