11-07-2022, 08:56 PM | #1 |
1931 oil pan
Recently pulled pan to clean-out and found several small holes (after blasting). My question is this, does the oil pump spring rest in the pan sump when everything’s together? The rusty area is in this sump area and I would like to cut it out, options??
11-07-2022, 09:25 PM | #2 |
Re: 1931 oil pan
yes and where you located I have about 6 pans?
www.whidbeymodelaclub.com |
11-08-2022, 04:08 AM | #3 |
Re: 1931 oil pan
11-08-2022, 11:14 AM | #4 |
Re: 1931 oil pan
4 clubs in Missouri area not sure if close to you. Go to mafca.com check at chapters list. Model A Ford Club of America.
11-08-2022, 07:00 PM | #5 |
Re: 1931 oil pan
Small holes are easily and quickly filled by getting a TIG rod of the same metal as your mig. Put the tig rod in the hole and start the MIG arc on it. Feed them together.
OPPPS.. I forgot.. Put a piece of copper on the other side of the hole first. Then do the welding. It needs to be copper, not brass or bronze. OTOH.... There are lot of extra pans around. Unless you have a late 31 pan and then you want to fix it. Last edited by Kevin in NJ; 11-09-2022 at 10:46 AM. |
11-09-2022, 09:29 AM | #6 |
Re: 1931 oil pan
11-09-2022, 09:30 AM | #7 |
Re: 1931 oil pan
Not sure if my pan is the "late' model or not
