Old 04-30-2024, 05:48 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default Manifold/Carb ID on a 54 FACEBOOK PHOTO
This photo was just on Facebook of a beautiful 1954 Monterey. Can anyone advise what manifold and carburetor he has on this 256 engine?? Car belongs to a Pat Kelly according to the photo.
File Type: jpg 424553564_10168919606395486_3197272366914724798_n.jpg (72.9 KB, 92 views)
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 05-01-2024, 02:33 AM   #2
KULTULZ
KULTULZ's Avatar
Post Re: Manifold/Carb ID on a 54 FACEBOOK PHOTO
Is there any contact info? You would have to contact the poster to either ask or to show a photo of the install w/o the CHI-CON SLOPPY COPY ACL.
Is yours still the stock 256CI 4V DUALING EXHAUST?
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL -
KULTULZ is offline   Reply With Quote
Old 05-01-2024, 08:15 AM   #3
Bob from Northport
Default Re: Manifold/Carb ID on a 54 FACEBOOK PHOTO
Yes, mine is still all stock, dual exhaust. No changes at all. 4 Brl tea pot carb
Bob from Northport
Northport, Michigan
Old 05-01-2024, 10:36 AM   #4
miker98038
miker98038's Avatar
I really can’t tell what I’m looking at on the manifold. It’s not engine color, but doesn’t really look like aluminum either. So maybe the oem cast iron painted silver?
To the best of my knowledge, which isn’t perfect, no one produced an aluminum 4 barrel manifold for the y blocks until the Blue Thunder. 2x3 and dual 4’s yes, but not single 4 barrels.
I know there are a few 2x3 out there with the small ports for the 239/256 engines.
I know, not much help.
miker98038 is offline   Reply With Quote
Old 05-01-2024, 12:48 PM   #5
KULTULZ
KULTULZ's Avatar
Arrow Re: Manifold/Carb ID on a 54 FACEBOOK PHOTO
How far do you want to go with modifications?
There was an EDELBROCK 4V intake available (F548). Might be hard to find one now. It had the square-bore bolt pattern so the CARB would have to be a WCB CARTER or an adapter to use a H4150 or FORD 4100.
The BEST thing to do (IMO) would be to go to a DUAL ADVANCE DIST (1957/ ) (w/ PERTRONIX II) and rid the engine of the LOAD-O-MATIC. It would make a huge difference without changing the OEM appearance much.
That ACL style is available BIRD or FORD repro -
Old 05-01-2024, 04:57 PM   #6
miker98038
miker98038's Avatar
K, thanks for the part number. Let me find an old post that identified it. No numbers here for the early dual quad though.
http://forums.y-blocksforever.com/To...?PostID=158038
Old 05-01-2024, 05:45 PM   #7
KULTULZ
KULTULZ's Avatar
Talking Re: Manifold/Carb ID on a 54 FACEBOOK PHOTO
You are welcome. It all depends on how far he wants to go with it.
I am sure you are familiar with, well if I do this why not this too?
- EYE CANDY -
File Type: jpg ROCKER COVER - MERC - The Y-BLOKE (AU).jpg (71.0 KB, 10 views)
File Type: jpg ROCKER COVER - MERC _4 - Block Letters.jpg (69.9 KB, 8 views)
