Old 01-11-2014, 02:18 PM   #1
Ken Arms
Ken Arms's Avatar
Default Another wheel and tire question
Would anyone be so kind to post some pics of your car with radial tires on 35 rims. Im about to spend gobs of money for a set of tires for my 34 project and I dont want to be disatisfied with my choice. I dont want to use bias tires since here in Vermont we have several roads in need of repair. I love the look of a "chubby tire" but I understand im limited by 4" rim width. I also want them to be wide whites. Im leaning towards a 215/70/r16 or 215/75/r16 from coker or Diamondback. Anyone going wider than 215? I think the 75 would give me a bit taller tire to help with highway speeds. Banjo is 354. Stock steering. all pics and comments welcome.Thanks so much Ken
Ken Arms is offline   Reply With Quote
Old 01-11-2014, 10:00 PM   #2
BILLF/TRF
BILLF/TRF's Avatar
Default Re: Another wheel and tire question
Ken, the wheels are '36 but the tires are 215/70 R16 with 3"WW from Diamond Back Radials. We like them especially with the 3.54 rear end and the T-5 transmission.
BILLF/TRF is offline   Reply With Quote
Old 01-12-2014, 10:12 AM   #3
Don
Don's Avatar
I am also looking for radials for my 35'and want the fatter look than the 600/16',sure would like to see a close up of the 215/r/16,wonder if Bill used tubes in his..
DON P
Don is offline   Reply With Quote
Old 01-12-2014, 11:22 AM   #4
Ken Arms
Ken Arms's Avatar
Bill, thanks a bunch, they look good! Do you know if 36 wheels are the same width as 35 wires? I believe 4" for 35. Im thinking I can go one size taller (215/75 since from what I understand the 215 is tire width and the 75 is percent of width in hight if that makes any sense. 75 would give me close to a 29" tall tire to help the 354 gears.
Old 01-12-2014, 01:35 PM   #5
BILLF/TRF
BILLF/TRF's Avatar
Don, my tires from Diamond Back are tubeless (on their recommendation!) and fit my 4" rims well. The only problem I had with air leaking was not tightening the valve stem base enough. Unfortunately I do not have any close-up pics of my tires handy but you could go on-line to Diamond Back (www.dbtires.com) and on page 24 they have pics of of their tires showing tread design. If you look through their catalogue, there is not a big selection of tires in that size. Mine are steel belted--for whatever that's worth--maybe rougher ride? Good luck, Bill.
Old 01-12-2014, 02:30 PM   #6
1oldtimer
1oldtimer's Avatar
http://www.fordbarn.com/forum/showpo...3&postcount=39
Fedral Tires 195/75r16 Ecovan, I bought them from a local dealer and they're Diamond Backs.
or these look promising:
http://www.dbtires.com/2013_catalog/hi/22.htm
1oldtimer is offline   Reply With Quote
Old 01-12-2014, 02:57 PM   #7
Don
Don's Avatar
I called about the new tire diamond back is coming out with,won't be ready till March ,then maybe June good looking tire tho.
DON P
