03-12-2024, 10:42 AM | #1 |
New Eddie Myers’s heads question
Has any body check there squish with these heads ? 59 ab , bored .030 Ross pistons , merc 4 in crank , and I have .085 squish with no head gasket , best head gasket measures .056 , seems way to much clearance to me , don’t I need like .040 total ? That would mean I need to take like .080 off heads ?? Will those heads be able to take that much off ?
03-12-2024, 10:58 AM | #2 | |
Re: New Eddie Myers’s heads question
03-12-2024, 01:11 PM | #3 |
John
Question the pistons are forged Ross standard bore plus and additional .030 ? Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
03-12-2024, 02:08 PM | #4 |
Squish: For a street engine you'll want .040 to .045 squish (with head-gasket one).
Are you sure you have the right pistons for the crankshaft compression height? How about posting a picture of the block/deck with a piston at TDC and also a picture of the chambers on the heads. You definitely don't want to have that amount of clearance over the pistons - so let's figure out what is wrong before you do anything. Also, how did you measure the squish? |
03-12-2024, 05:48 PM | #5 |
What you really need to know is how far down in the cylinder the outside edge of the piston is at tdc. If that's very far down you'll never get the quench (squish) correct. A few thous. above the deck is better.
03-12-2024, 07:08 PM | #6 |
03-12-2024, 07:47 PM | #7 |
I remember back in the 1960s when a guy saw a pair of aluminum heads that he liked he bought them. Then he went to the parts store to get a set of head gaskets. Probably bought what the parts guy told him was best. He installed the heads without any knowledge of "squish". He was so proud of his cool looking engine. The engine ran well and he was happy. Is this scenario not possible anymore for the average guy? Do we all need to measure squish for an old stocker engine to run good enough for weekend drives?
03-12-2024, 09:24 PM | #8 | |
Ronnieroadster
03-13-2024, 10:11 AM | #9 |
I'm a bit of a perfectionist . . . can't help myself! LOL
03-13-2024, 11:39 AM | #10 | |
But then again, I'm a real fan of optimum quench. |
03-13-2024, 12:29 PM | #11 | |
03-13-2024, 12:37 PM | #12 | |
There were a lot of things I didn't know back then, either. Last edited by tubman; 03-13-2024 at 12:55 PM. |
03-13-2024, 02:07 PM | #13 | |
To answer your question its simple I would do what's needed to get the clearances where I like things. However as I wrote checking for clearance is what most guys do to determine things clear and nothing more. If there's clearance then the heads are just bolted. Here's a couple of questions for you Tubman. That 276 inch flathead engine you wrote about which you were never satisfied with the power it produced did you change the cam in that engine to something other than stock? If the answer is yes did you check the cam timing? Ronnieroadster
03-13-2024, 03:00 PM | #14 |
I found many years ago that sometimes what you think is right just isn't. In my book is a chapter on checking compression, It's pretty much the same old measure the size of the stroke, add alittle something for the head gasket and combustion chamber volume (had to make a fixture for that) and your there?? Or are you?? I found there are too many variables. Now I just put the piston down about 1/4" slap on an old head gasket any pore in some colored windshield wiper fluid from a 20cc beaker and measure the amt. Then do the arithmetic. Makes a big difference, usually lower than you thought. Don't forget to raise the piston.
Gramps |
03-13-2024, 07:42 PM | #15 | |
What I don't understand is how this has changed from a legitimate discussion of head preparation to a discussion of cam timing. I did not check the cam timing or the squish in the heads; my bad. I have to assume that the cam was correctly ground and installed by a reputable builder. You can't second guess everything. Let's remember the question posed by the O/P and not get side tracked by what may or may not have happened thirty years ago. |
03-13-2024, 09:28 PM | #16 |
They are new orosco heads , I did get some pics but not smart enough to know how to post them , can some help here
03-13-2024, 11:47 PM | #17 |
These are all of John's pics that I could get to post. Coop https://apis.mail.yahoo.com/ws/v3/ma...ilNorrinLaunch |
03-14-2024, 07:04 AM | #18 |
Best I can measure is piston on edge of cylinder is .025 below the deck , thanks coopman for posting
03-14-2024, 08:16 AM | #19 | |
If that measurement is at TDC, I will defer to the experts like Ronnie, Pete, Ol' Ron and Bored & Stroke. From the little I understand, milling the heads won't solve that. This is a piston issue. |
03-14-2024, 10:06 AM | #20 |
I noticed my post said 20cc beaker it should be a 200 cc one or measure thr chamber and use a 20cc beaker.
I think??? Gramps |
