Old 06-10-2012, 07:32 PM   #21
glenn in camino
glenn in camino's Avatar
Default Re: 30 Coupe. Gonna Have To Raise the Dead
Youi are a brave and talented guy. I've always started with the best, most complete Model As I could find.
glenn in camino is offline   Reply With Quote
Old 06-11-2012, 06:46 AM   #22
Richard Wilson
Richard Wilson's Avatar
Really good advice from Glenn. My version is "always start with the best, most complete Model A that you can afford." In my world those are usually not the same ones Glenn is talking about.
Richard Wilson is offline   Reply With Quote
Old 07-13-2012, 10:20 PM   #23
Flop
hey thanks guys !! i skipped some hot rods steps i took but still figured you would like to see some structure pictures and maybe the measurements will help someone out down the line
well almost time to get the patches put in
fixed the inner structure tonite
i had one side that i could take some measurements from lucikly
not the prettiest but it worked. from right below the bottom hinge bolt to the bottom of the post is 7 & 15/16ths
and the other side
and how it turned out
also got one side of the firewall spotwelded in again !
Please call or email while website is down!
412 867 1659
[email protected]
https://www.facebook.com/flop.custom
Flop is offline   Reply With Quote
Old 07-25-2012, 09:07 PM   #24
Flop
this thing is getting less rusty by the day ! subframe connectors in ! patches tomorrow!
re-riveting these rad support brackets really made my day for some reason!
and if anyone needs some meaurements.. its 15 inches from the 90 degree angle where the subframe connector meets the inner pillar up to the support on the upper pillar that surrounds where the arm from the firewall enters.( if that makes any sense)!
412 867 1659
[email protected]
Old 07-26-2012, 08:14 PM   #25
Flop
sorry there is a little hot rod thrown in but i figure you guys would still like to see the rust repair
got some patches from snyders today . i expected them to be the full bottom but nope.
the tig likes those gaps tight!
all welded up
i guess they dont expect people to be fixing super rotten cars . so i had to add this piece
in place
this little piece was the biggest pain of the day took a few attempts to figure out how to make the weird bead shape
and this is it all said and done minus the rivet to the subframe connector
412 867 1659
[email protected]
Old 07-28-2012, 05:51 AM   #26
Flop
passenger side lower cowl . got the major welding done now just have to do the 2 detail pieces that dont come on the patch panel .
412 867 1659
[email protected]
Old 07-28-2012, 07:02 AM   #27
CountrySquire55
CountrySquire55's Avatar
Love seeing pictures of your work. You are a master with metal!
CountrySquire55 is offline   Reply With Quote
Old 07-28-2012, 07:08 AM   #28
Banky
Unreal man!
Banky is offline   Reply With Quote
Old 07-28-2012, 07:18 AM   #29
peters180a/170b
peters180a/170b's Avatar
Beautiful work.... Now i am sorry passing up on another 180A body to be restored. It would of been a walk in the park for you. If you have a spot at HERSHEY MEET this fall showing your work let us know.
peters180a/170b is offline   Reply With Quote
Old 07-28-2012, 09:36 AM   #30
Not George
Not George's Avatar
Kinda figured it would be a hot rod from the first post, but that's OK.
Not George is offline   Reply With Quote
Old 07-28-2012, 09:59 AM   #31
Tom H.
Tom H.'s Avatar
Really nice work. Just my opinion, but I think if you have the talent to repair that body, you should build it into anything you want.
Rear fenders and running boards for 1932 131" single wheel Express Body needed.
Tom H. is offline   Reply With Quote
Old 07-28-2012, 05:39 PM   #32
Flop
thanks alot every one i really do appreciate all of your comments !!
peters.. I will be at hershey but I will be doing some shopping . it would be nice to meet up with some of you folks if you have spots!! then I am heading to Jersey after to work in a shop out there for a few days .
i got a pm about how i made the weird break /bead on the fire wall . so hopefully this will help some of you guys out down the road if you ever have to make this piece.
this took me a while to figure out but its relatively easy once you know how to do it .
fold a piece of steel in half . i started it by hand then finished the job with a body hammer
unfold then find a way to make the bead deeper . i myself used a small opening in my vice with the chisel end of the body hammer made it more pronounced
then i had to work it more to match the bead once it was on the car
and thats what it looks like all finished up
also had to make this piece but its just a simple break
still have to fill a few pits but im about 99% done with the cowl now!!
412 867 1659
[email protected]
Old 09-03-2012, 07:45 AM   #33
Flop
snyders sells the cross channels for 75. i had 25 dollars worth of sheetmetal and labor into them from the local hvac shop
412 867 1659
[email protected]
Old 09-03-2012, 08:10 AM   #34
Kevin in Mass
Verrry nice work!
Kevin in Mass is offline   Reply With Quote
Old 09-03-2012, 08:21 AM   #35
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
What's that flathead in one of those pic up against the wall with the finned heads and the exh manifolds on top? Is that a Caddy? Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 09-15-2012, 06:30 PM   #36
Flop
thanks Kevin!
Walt that is a 41 caddy flathead
picked this up at canfield as well
the holes cancel out how solid this panel is !!
412 867 1659
[email protected]
Old 09-22-2012, 09:12 PM   #37
Flop
worked on the panel under the decklid today been a while since i messed with my own stuff
412 867 1659
[email protected]
Old 09-24-2012, 06:20 PM   #38
Flop
before
and some after action
progress !! now gotta wait till hershey to find some doors and hinges and maybe the inside of a decklid .
412 867 1659
[email protected]
Old 09-24-2012, 10:19 PM   #39
C26Pinelake
Sell it for parts !
C26Pinelake is offline   Reply With Quote
Old 09-25-2012, 01:16 PM   #40
C26Pinelake
Without being obnoxious, do you have any idea how much this project is going to cost you ? That might be the best place to start ( figureing cost ) before putting welding torch to work. I think you relaize by now that no matter how little you paid for it you definitely did not steal it !
The seller likely has a big grin on his face that he was able to find a buyer !!
